4430 Questions
Tim A.
01-02-2005 19:30:27
I have a 1973 4430 and have the following questions I was hoping someone could help me with:
Question #1: Regarding the starting fuel control linkage on the injection pump, there is no 'control rod' on the pump and the bellcrank (that is what it appears to be called in the manual)is hard wired in the aft position...is this something I should be concerned with...is this to correct a known problem with the injection pump...something I should replace...or just leave the way it is? This is my first JD and by far the largest tractor I have owned, but it seems to me that I have seen this on other tractors at auctions and such...but my neighbor seems to think it is something I need to look into.
Question #2:This tractor wanders back and forth quite a bit, especially when traveling on the road. I have watched and cannot noticeably see the front tires move left or right when it starts to wander. Is this sort of problem generally a bearing/bushing problem in the front end, or would it more likely be in the hydraulic components of the system. The 'feel' of the steering seems fine and it is responsive.
Thank you for your help.
Tim
Tim A.
01-03-2005 16:53:11
 Checked Tie-Rods etc in reply to Tim A., 01-02-2005 19:30:27
Was able to hustle tonight after work...and jacked up one side...was surprised to see how much end play there was in the tie-rods...allowed close to 1/2 inch movement in tire. Also, appears to be some wear in the spindle bushings. If fixing these problems doesn't completely fix the problem, it should at least tighten her up a bit...so to speak.
Copied the correction in the toe...
Thanks for the inputs!!
Tim
msb
01-02-2005 20:20:52
 Re: 4430 Questions in reply to Tim A., 01-02-2005 19:30:27
Forget the injection pump.Leave it wired as it is.Details would probably mean little to you.
Wander in steering could be either in the steering motor up front or the steering valve itself.Unless it gets worse,I would probably not worry about it.There is a test to see if it is in the steering motor.It may or may not be something you want to do.If so,post back.Someone will tell you how to do it.
Have you jacked up the front end and checked for play in the tie rod ends? Also check for play in the spindles.The wander could be coming from any of them.Also check the toe in.I set the front about 1/4" wider in front.
thurlow
01-03-2005 08:36:25
 Re: 4430 Questions in reply to msb, 01-02-2005 20:20:52
Mis-print???? toe-in one quarter inch wider in rear???
Tim A.
01-03-2005 04:46:20
MSB: Thank you for the information. I have not gotten a chance to jack up the front yet, but am hoping to get to that later this week..depending on the rainy weather expected here in N. Texas this week. To me, the spindles appear that the bushings may be warn, but won't be able to tell until the front is jacked up. I will start with the easiest stuff to fix and work my way back...from a brief look at the manual, if the problem is in the motor or valve, it may be a problem I will learn to live with.
As for the injection pump, I would be interested in a brief summary on why it is hard wired anyways.
Thanks Again,
Tim
