jdemaris
01-03-2005 06:34:27
Re: 2010 JD crawler in reply to Ben/Green, 01-02-2005 19:07:46
Kind of hard to diagnose without more specific information. First of all, if you replaced the coil, what did you use? It's supposed to have a 6 volt coil even though it's a 12 volt system. Deere did this with many of their gas engines. And, you say you replaced the ignition switch with a garden tractor switch - what kind of switch? They basically come in two versions for garden tractors - those for magneto ignition and those for battery ignition. If you have a switch for magneto tractors, it won't work since it won't feed any power to the igntion circuit. You don't need a switch just to get it running - as as far as the old switch working with a screwdriver - they were like that when the machines were brand new. Just get power to the coil, use a jumper wire if necessary. I don't know if you've got the system hooked positive ground as it was originally, or the opposite. The coil doesn't really care, most will work either way, but most will work more efficiently with the polarity they were designed for. Anyway, one terminal to the points, the other to the power source. Points must be "making and breaking", that's why they are called "breaker" points. Pretty simple and straight forward system. Deere did have a few updates, though. Deere kept making changes on the way a resistor was used for power to the coil, and also the way it was bypassed when cranking. At one time, the resistor was built into the ignition switch with bypass built into it. Later changes and variations followed. There are many other ways to do it. If you have a Delco starter, just use the bypass terminal on the solenoid marked "R."
