Antifreeze Leaks from John Deere LA .
AWB
01-02-2005 17:19:19
I am experiencing some problems with antifreeze leaking out between the cylinder head and the block. After removing the head I noticed that some of the headbolts holes in the block seem to extend into the coolant chamber in the block. How does one go about correcting this leak problem? Thanks in advance for the help.
Larry E
01-02-2005 17:57:37
 Re: Antifreeze Leaks from John Deere LA . in reply to AWB, 01-02-2005 17:19:19
You could put in a bottle ot Bars leak.It works good.Can get this at Walmart or aut supply.
Larry E
01-02-2005 17:57:26
Larry E
01-02-2005 17:40:20
remove studs 'clean assemble with teflon tape or good heat resistance pipe dope,Loctite makes several types.
Deeredale
01-02-2005 18:52:36
 Re: Antifreeze Leaks from John Deere LA . in reply to Larry E, 01-02-2005 17:40:20
Seal the threads.
