'50 B fan shaft ratttle
mattd
01-02-2005 17:00:14
i have a 1950 B which i restored a few years ago, which is now a "trailer queen". and when it runs at a certain speed (around 600-700 rpm im guessing) the fan shaft will hit the inside of the shaft tube its in. it never did this before i restored it. and i dont remember bending or dropping the shaft. it'll only do this at a certain speed and i can run it but only faster or slower than when it makes the noise. im guessing the bearing is going bad inside the govenor. has anyone had experiance with this or know an easy fix. you can probably guess i dont want to take it all apart again. thanks for any help
RalphinWI
01-02-2005 20:58:32
 Re: '50 B fan shaft ratttle in reply to mattd, 01-02-2005 17:00:14
I had a nice rattle!! in my 50 A a few years ago. I was conviced the fan was "eating" the radiator but couldn't see any areas of contact. On disassembly, we discoved one of the fiber disks in the fan clutch had disintegrated, allowing the "nubs" that hold it in place to contact each other when the clutch slipped. We replaced all the bearings in the gov and the fan shaft plus other worn parts.
