50 Hood
rej
01-02-2005 13:41:49
O.K.,I've got the nose cone off,drained gas tank,taken choke rod off. How's the best way to take steering rod off,also will the steering wheel have to come off too? thanks
Dan in ohio
01-02-2005 13:57:08
 Re: 50 Hood in reply to rej, 01-02-2005 13:41:49
rej,
Sounds like you have done the hard part. That steering rod needs to come off. You just remove a pin that is through the steering rod(it is under the nose cone you already have taken off). I leave the steering wheel attached and use the hub to tap against. That steering rod should slide out with some light tapping with a hammer. I take the muffler off too, unless you want to lift the hood over it (clumbsy manuver with the tank attached). My 70 D fuel tank is not attached to the hood, I have not had the hood off my 50, yet.
Dan in Ohio
01-02-2005 14:07:54
 Re: 50 Hood in reply to Dan in ohio, 01-02-2005 13:57:08
rej, My memory is working alittle better now, as I recall I did have to take the steering wheel off as it could not get past the seat frame other wise. My tractors have power steering too. That pin through the steering shaft is a roll pin secured with a wire tye.
Clooney
01-02-2005 13:44:45
rej, power stering or manual steering? It makes a difference...
Clooney
rej
01-02-2005 14:34:29
 Re: 50 Hood in reply to Clooney , 01-02-2005 13:44:45
It's manual steering. The best i could tell, I do not remember seeing a roll pin,maybe I haven't looked hard enough. The steering box has a plate on the right side an a plate on the front. I have already taken the muffler off. REJ
Clooney
01-02-2005 15:02:34
 Re: 50 Hood in reply to rej, 01-02-2005 14:34:29
rej, on the manual steering you have to remove the steering wheel, then pull it off (sometimes not easy),, then either pull the steering worm box off the side of the top of the font bolster, or pull the front worm bearing housing & screw the worm out the front.. I always pull the worm housing myself. Make sure you keep the gasket(s) as those are also adjustment shims & either re-use them, or buy new to equal the same thickness as removed..
Clooney
rej
01-02-2005 15:10:24
 Re: 50 Hood in reply to Clooney , 01-02-2005 15:02:34
Thanks, I'll give it a try tomorrow. If I run into any problem I'll get back in touch. rej
rej
01-02-2005 17:41:49
 Re: 50 Hood in reply to rej, 01-02-2005 15:10:24
Clooney, you are saying if i remove the 4 bolts in the steering box,(3 short,1 long) it will just pull away from the pedistal,and with the steering wheel off , I can then slide the steering rod out of the hood. rej
Clooney
01-02-2005 17:45:49
 Re: 50 Hood in reply to rej, 01-02-2005 17:41:49
rej, yes..
