36 jdb steering
xragman
01-02-2005 12:28:01
bought it last year 03 . noticed rightaway it turns more to right than left. ben working on other things all year, finaly got around to checking it out.sector gear goes to stop pin in each direction.how do I fix this?
Clooney
01-02-2005 12:32:17
 Re: 36 jdb steering in reply to xragman, 01-02-2005 12:28:01
xragman, how much more does it turn one way than the other? If a lot, suspect the sector gear is off a spline.. If only a little suspect a twisted front vertical steering shaft..
Cooney
xragman
01-02-2005 15:22:29
 Re: 36 jdb steering in reply to Clooney , 01-02-2005 12:32:17
if I knew how to type, it would help.the sector gearonly has 6 splines, making each 1 60 degrees of circle. it turns left 46* & right 76*by my H F protracter. I suspected twisted spindle shaft. any idea how to fix it?
Clooney
01-02-2005 15:38:56
 Re: 36 jdb steering in reply to xragman, 01-02-2005 15:22:29
xragman, I really don't know what to tell you.. It really depends on where it is twisted.. If at the bottom where the lower casting is put on maybe it�s repairable.. If the shaft is twisted probably not.
I have owned a few old �A�s� with twisted steering shafts & usually just find a good used to install.
Probably just have to pull it apart & see if you can find the area that is causing the problem then go from there..
Can you tell how centered the sector gear looks when the front wheels are pointed straight forward? If it is pretty well centered maybe the sector is worn at the stop pin area due to a life of turning one direction when plowing or cultivating..
Clooney
