1010 utility
Dale Kurtz
01-02-2005 08:11:53
I have a 1010u that runs great once it is started. However getting this thing to start is quite a challenge. You have to pull the choke closed then open then closed then open while cranking. Then when it does start it will pour black smoke, clear out and run fine. I am a proffessional auto tech. I rebuilt the carb. I am wondering if maybe the spark timing is off. I am open to suggestions. I really like the tractor except starting it. I hope someone can offer advise on how to cure it. Thanks in advance.
Hayfarmer
01-02-2005 14:16:10
 Re: 1010 utility in reply to Dale Kurtz, 01-02-2005 08:11:53
my NAPA dealer could order the electronic ignition but his supplier didn't have one for my 2 cylinder so I had to get it on line. The biggest advantage is that you never have to adjust or change points again. You can also run awider plug gap.
Dale Kurtz
01-02-2005 11:03:38
Thanks guys, old tractors are a bit different from what I am accustomed to workking on, except they still suck, squeeze, explode, and extract the air. Its the liitle tricks that the fellas that have been around them know, that come in handy. Does anyone know how much compression a 1010 gas should have. I would guess 100-120. I have not checked this tractor yet. Also was wondering where to get an electronic ignition as stated in previous post. Thanks.
Bob
01-02-2005 11:34:34
 Re: 1010 utility in reply to Dale Kurtz, 01-02-2005 11:03:38
For the electronic ignition, go to :
www.pertronix.com
and use their on-line catalog to get the part number, and then shop around. Pertonix makes the modules that certain other outfits resell. Often, you'll find a local auto supply that can order a Pertronix unit, and maybe give you a deal on it below the "list" price. A school bus dealer near me sells the units WAY cheaper than many of the on-line sites.
THIS YT site sells them, too, if YOU want to order it yourself.
Be sure the ground polarity of the ignition unit you order matches the way your tractor is set up.
Hayfarmer
01-02-2005 09:42:52
I agree with the other post on points, condensor etc except that I think I would put the $20 bill the points and condensor are going to cost you towards an electronic ignition. I have a 430 and finally did that with mine. With $20 for points and condensor at NAPA you pay for it quick. Plugs are the other thing that are critical for starting. I went to a hotter plug in my 430 due to the unleaded gas now. While in the distributor make sure the advance is working, I had to free mine up a while back. After you get it all together check timwing with a timing light. Not sure how the 1010 times but check the book for it.
Loren NC
01-02-2005 09:03:21
Who am I to give advice to an auto tech? Oh well, here goes! I have a 1010 and had similar problems with it when I first got it. After a lot of fooling around, I found out that points, condenser, rotor and distributor cap made a HUGE difference. I found all of them through my local NAPA store so didn't have to pay an arm and a leg for them. After I put all of those parts in, I still had erratic performance for a long time. Then I discovered there is a fine-screen fuel filter inside the top of the carb. Take out the fitting where you attach the gas line and take a look at the filter attached to it. Mine was completely plugged. It is a bit of fun to pick out the debris from inside it, but that would also make a huge difference if yours is plugged as mine was.
