Adding a remote to 2040?
Scott Hibbs
01-02-2005 06:23:53
I am buying a 2040 (1980?) but it has NO remotes. Is this something expensive/difficult to add?
Thanks
Scott
Anthony Q.
03-19-2005 20:16:03
 Re: Adding a remote to 2040? in reply to Scott Hibbs, 01-02-2005 06:23:53
Hello, I'm buying a 2040 as well, and it has no remotes. Did you ever get yours installed? I spoke to the John Deere dealer about it, and he said it would cost around $1500 to install a remote system from JD spare parts.
I just don't think it would cost THAT much! Here is a Tractor Supply website that seems to have hydraulic valves (single and double) --Link
The>Link dealer also recommended checking with salvage yards.
Hey, let me know if you find a couple of assemblies that will fir the JD2040...and I'll do the same if you haven't taken on this project yet.
Thanks in advance!
Anthony Q.
Allan/NCA
01-02-2005 14:19:05
I'm not close to the tractors now but if you can't get the info from the dealer i'll get it for you. Years ago we installed remotes on 301A JD and the dealer told us whitch ports were hot and the return port and we got an after market set of valves and hoses and it worked great. If you have someone close by, you can just copy the way they installed it. Its pretty much the same from 1960's JD300 ,2640,to 2355 so if you find like tractor just copy. Good luck Allan
