JD 4020
Beeman
01-01-2005 18:41:01
HOW MUCH DOES A 4020 WITH A WIDE FRONT END AND CALCIUM IN THE TIRES WEIGH ? WHAT IS A 4020 THATS RUNNING WITH GOOD SHEET METAL WORTH ? ANY HELP WOULD BE A GREAT HELP.
Gerald J.
01-01-2005 18:52:48
 Re: JD 4020 in reply to Beeman, 01-01-2005 18:41:01
About 8000 for the tractor. Up to 2162 pounds for water and CaCl2 if the tires are 3/4 full.
I paid 5250 about 5 years ago for a gas 4020, diesel 4020 were going for several thousand more, more for side console.
There were three versions of the 4020 family, breaks at serial numbers 91,000, and 201,000. The tractors after 201,000 generally bring a higher price and many parts don't interchange with the earlier 4020.
Gerald J.
BEEMAN
01-01-2005 19:20:18
 Re: JD 4020 in reply to Gerald J., 01-01-2005 18:52:48
I DONT KNOW MUCH ABOUT THE FORTY-TWENTIES, JUST HAVE AN OPPORTUNITY TO OBTAIN ONE. THOUGHT I'D START HERE FOR THE VERY BASIC INFO BEFORE I BRING HER HOME. WHERE WILL I FIND THE SERIAL NUMBER ON IT TO FIND OUT THE YEAR?
Gerald J.
01-02-2005 07:57:47
 Re: JD 4020 in reply to BEEMAN, 01-01-2005 19:20:18
Go to ebay and buy an owner's manual, it may bend being the wrong one but reading it can put you one up on the seller. Ditto an I&T shop manual.
I've run my 4020 for a few years and become more intimate with some of its parts that I've ever wished. Its a good piece of machinery, but it can be broken and can wear out. Parts are readily available and its capable of a good day's work. It is not the most economical on fuel, especially the gas tractors, but that reputation cuts their selling price far more than my expected fuel consumption over at least 14 years of use. Gas consumption can be moderated by care in tune up making sure its not running rich from worn carburetor parts and air intake restrictions as well as making sure the ignition parts are good with proper timing.
Its easy to add a loader hydraulics without loosing the remote(s).
Gerald J.
Bob
01-01-2005 20:18:37
The serial number is on the rear end casting of the tractor, above, and a little to the right of the drawbar and PTO area. (If it has a PTO.)
