Thanks for the response. From the JD parts catalogs it appears from JD there are 2 choices available, one apparently a stock replacement and the other a "conversion kit". Now from Hy-Capacity they show a bit more detail, there is a 12 5/8"(which is apparently discontinued by JD), a 12 7/8" and a 13" Conversion Clutch (which requires flywheel machining). All have the same 1 1/4"x 10 spline clutch disk and a 1 3/4" X 27 spline pto drive hub. I have the best manual JD says that is available (a IT&T with a JD company insert in it sold by JD)and it makes no reference to any of this. My local dealer has no actual experience with what evidently is somewhat of a orphan tractor according to them. I have been surfing the net looking for more info and have noticed quite a few references to difficulty obtaining parts. While perusing the JD parts catalog it also appears there are some transmission conversion kits available as well so I'm wondering if this tractor has some issues to begin with and it would be best for the owner to send it down the road to the local consignment sale asap. Right now here in SD everything is under a nice coat of ice so I won't be able to get you a serial # until things thaw a bit...lol but it does not have a reverser and has a 16 sp (2range/8speed) transmission. The owner was using it to dig out rocks and admittedly abused the clutch into submission. Doc
