50 Hood
rej
01-01-2005 15:01:25
I want to take the hood off my 50 so I can get a few dings out and paint it. Is the gas tank attached to the hood. This tractor does not have power steering. Any tips appreciated. thanks , REJ
old bones
01-01-2005 19:59:55
 Re: 50 Hood in reply to rej, 01-01-2005 15:01:25
i took the hood/tank off my 49 A last summer for painting, and the hood/tank of my 60 this week for radiator repairs. if your heat shield is still in place, it will be much easier to take the whole hood/tank assembly off, tip it upside down on a pair of sawhorses, and remove the heat shield and fuel tank. the clamps that hold the tank to the hood would be extremely hard to re-install sitting on the tractor (you'll see what i mean when you take them off). could be really hard on new paint, let alone your fingers and knuckles. also, you can clean out any mouse nests, if any (i had old nests in both my hoods), and you can inspect the generator wiring harness at the same time. removing the hood/tank isn't that bad. a couple of hours. drain the gas first. get somebody to help you lift it off, though.
old bones
Clooney
01-01-2005 17:34:40
REJ, tank comes off with the hood but you could kind of do the hood & then the tank in 2 pieces if you want to spend the time & effort to remove all the fasteners while still in the tractor..
Clooney
rej
01-01-2005 20:14:18
 Re: 50 Hood in reply to Clooney , 01-01-2005 17:34:40
Thanks fellows. Clooney I got the carb bowl back on today,new gasket and used a little permatex and for the attaching nut I used a 1/2" black pipe cap, same threads. Tractor runs great, so far no leaks. REJ
