Power Block Sleeve Replacement 6-3 Model 1
LJS
01-01-2005 13:36:00
I have 6 2 power block that I might need to replace one sleve in due to the fact the previous owner forgot to put wrist pin keepers in.
Do you know of any sources for this and it as simple as pressing the bad one out and pressing the new one in.
Thank
Lynn S
Pullin A
01-02-2005 10:50:03
 Re: Power Block Sleeve Replacement 6-3 Model 1 in reply to LJS, 01-01-2005 13:36:00
I just had this done a couple months ago in Bay City, Mi, at the carquest machine shop. They rebored, sleeved it and rebored it back to 6.125, my specs not standard. The O-rings are fine even after their third bore job. I tried to find somone to pull the sleeve and press a new one in like you are talking about but everyone said it would probably break the webbing in the block, and the new oring will be hard to get to seal. I searched a lot and none could find a tsc sleeve either. If you find them, give me a shout on email, because we have another one to do.
Thanks
buickanddeere
01-01-2005 22:05:35
I think? someone said something about Dengler Tractor putting new "O" rings in a TSC power-bloc. Thier contact info is listed on the johnnypopper info/link page. I sleeved the worn sleeves in a worn 5-3 block. Seems to work OK. The new sleeves we insertd are much harder than the TSC sleeve material. We are hoping the machining of the old sleeves overisze and pressing a stock bore sleeve into them won't make the old O'rings leak.
LJS
01-01-2005 13:46:27
 6 2 powerblock not a 6 3 in reply to LJS, 01-01-2005 13:36:00
Screwed that post all up, double posted and had the wrong numbers on it. I have a 6 2 power block not a 6 3
Thanks
Lynn
