David L, if you are if you are installing the vinyl decals soapy water won�t work.. Soapy water works best on the paper type & transfer kind.. On the vinyl I have found that you MUST be working out of the wind or risk a big problem.. Next make sure the surface is clean without ANY nibs or dirt where the decals go. Then I usually tape the decal in place with masking tape until EXACTLY where I want it.. Then run a full length of masking tape along the top,, � on the decal & � on the painted surface. Then run a few strips of masking tape vertically across the full length tape�The idea here is to make a foldable tape hinge.. Then fold the decal up & remove the paper backing.. Then gently fold the decal down while gently starting at the top & allowing it to contact as it folds down.. {You might want to practice this move BEFORE removing the backing} Once it is on don�t mess with it.. Use your hands or a roller & flatten as much as possible but DON�T poke holes to let the air bubbles out.. Then put the tractor or hood or whatever in the direct hot sun.. You will come back later & the air bubbles will be gone.. I�m sure this isn�t the only way but have found it to work good for me.. I only use good quality decals so not sure how this would work on cheaper non vinyl ones.. Good Luck_____Clooney
