730D Cooling system
CFWelles
01-01-2005 05:59:39
I posted here about three weeks ago asking for comments on the likelihood that a 730 could drive oil into the coolant. Received several helpful responses. Since I don't have a heated shop yet, I finally had an opportunity yesterday to get into the coolant system with temps in 40's. First, by removing the housing around the thermostat I was able to easily remove the the thermostat without having to take out the hot water tube with its tight o-ring type seals. I gave it a good flush with a commercial caustic solution with the thermostat out because the waterside was just too dirty. Had suspected an oil contamination problem, but didn't find enough evidence of oil to support concern. Also had checked head bolt torque after one of you advised. Torques were OK (275 ft-lbs) with the center two bolts slightly under. When I put in new coolant, I found that I had to go put a load on the tractor to get warmed enough it to mix well. Have yet to see the coolant system build pressure. These appear to be very conservatively cooled systems. Looks like you don't see high temps unless you are working this pretty well in the summer even with thermostat in. Maybe thermostat is bypassing enough flow to keep it just warm and not hot. Have I observed this right? In summary, some of you said that these are not typical oil contaminators because of the interface of oil and water is only at the head gasket area. My experience fits this. My system was just full of heavy iron oxide from neglect. Now I have got clear green coolant. Thanks for the original posts on my question. I am new to this machine, but am in awe of the common sense layout, serviceability, and reliability of this machine. I am beginning to understand why all you experienced fellows love the 730D's.
720Deere
01-01-2005 07:19:17
 Re: 730D Cooling system in reply to CFWelles, 01-01-2005 05:59:39
I have found that the large pony start diesels are next to impossible to maintain temperature on unless they are being worked hard. Electric start diesels have less coolant and iron to dissipate the heat and seem to come up to temperature even at idle. Another cause of low operating temp is the fact that those diesels draw a huge amount of cool air through them which has it's own cooling effect.
My 720D requires the majority of the radiator to be blocked with cardboard to maintain any kind of temperature. I have tried several thermostats with similar results. My brother has an 80 that acts the same way.
As to oil contamination, the only way that I see that being possible is through a pony motor. I don't remember if your 730 is so equipped. The water pump seals on those ponies can swap an awful lot of coolant and oil.
CFWelles
01-01-2005 07:22:33
 Re: 730D Cooling system in reply to 720Deere, 01-01-2005 07:19:17
I should have stated that I have an ES. Thanks for your comments on the cooling.
CFWelles
01-01-2005 06:15:01
I think I erred when saying that there is an oil /coolant interface at the head gasket area, at least pressurized oil. One of you responders to my original post warned of blowby at the head gasket from loose bolts or a bad gasket. Coolant was just so dirty that I suspected a possible problem. I don't believe I have a problem there now. I did finally notice a fair amount of tappet noise. Guess I better check valve lash. I posted here out of respect and appreciation for the posts given on my original inquiry. These responses are of great help in providing useful suggestions of what to look for when you are looking into something. To the fellow who advised not to use a cleaner in the coolant, all I can say is that this thing was too dirty to just do a water flush. Guess I'll have to take my chances with the water pump seal. Made sure I did a thorough clean water purge after the cleaning to get all the caustic out. Thanks for your help.
F-I-T
01-01-2005 06:37:10
 Re: 730D Cooling system in reply to CFWelles, 01-01-2005 06:15:01
CFW:
Good deal on getting it cleaned up. Sometimes when they are that dirty, you have no choice but to get them cleaned. Yes, you could "cause" a leak at the water pump seal or even in the radiator core, but my experience is that the holes are there and they"ll leak eventually anyway.
Not sure where you are located, but when warmer weather arrives, you might try this. Drain your new coolant into a clean container so you can reuse it. Add clean water with a cup of washing soda per gallon (some books said two cups per gallon). This will act as a mild water softener and ionizer, and it will cean the system even better. Then apply a mild load if you can to get it to circulate and warm up. You"re right, 70/720/730"s are pretty hard to get hot because there is so much cast iron and radiator compared to other machines. A good day of working ground would be perfect. Drain it warm, but not hot, maybe follow with one more swish of clear water, and then reinstall your coolant.
I think you"ll like the results.
Frank
