Just how does this electrolysis work?
chrisfromsolitude
12-31-2004 18:40:15
Got to reading other discussions and was wondering how this whole thing works. Is the setup easy to build? How do you do it? Thanks for any info and happy new year.
Mike in Louisiana
12-31-2004 19:07:52
 Re: Just how does this electrolysis work? in reply to chrisfromsolitude, 12-31-2004 18:40:15
Chris,
Go to Frank In Tallahssee's WEB page WWW.FBOERGER.COM and the whole process is explained. I recomend You try it. I don't think you will find any negitive complaints about the process. It is cheep and works great. TRY IT
Mike
F-I-T
12-31-2004 19:03:46
Chris:
I have an article on my website that will get you started. rEad that then if you have any questions, I'll be glad to help if I can.
Frank
Leroy
01-02-2005 06:15:33
 Re: Just how does this electrolysis work? in reply to F-I-T, 12-31-2004 19:03:46
Frank, I just for the first time actually looked at your web site and the section amout the J D A, 3 bros J. D. dealership would that have been Koenig's? 2 bros would have been Grilliot a bit closer to Minster
F-I-T
01-02-2005 15:57:44
 Re: Just how does this electrolysis work? in reply to Leroy, 01-02-2005 06:15:33
Leroy:
Well, you are close. The dealership (still in business) is Willowdell Sales, in Willowdell, Ohio, just SW of Ft. Loramie, and north of Russia.
The brothers were Dick, John, and Bob Simmons. Their dealership is a very old one. As an aside, Willowdell is near Annie Oakley's birthplace. She used to trade game at the general store there for powder and shot.
Koenigs came along on our area later into the 70's.
Frank
Leroy
01-03-2005 06:21:11
 Re: Just how does this electrolysis work? in reply to F-I-T, 01-02-2005 15:57:44
I have been to Willowdell, didnt know it was 3 bros. Koinig's have been in Botkins for over a 100 years with the first years as McCormick dealer before going to John Deere in the 30's. Question on electrolysis. have you ever tried cleaning bearings with it? if so how did it work? I have a big old Wisconsin engine that I got free that is stuck and was wondering if could cook the whole engine to loosen to take apart. Lester
Loren NC
01-01-2005 14:28:33
 F-I-T put this in your pipe and smoke it once! in reply to F-I-T, 12-31-2004 19:03:46
You are clearly the acknowledged electrolysis expert here so this might be an easy question for you on a related issue. I have a strand of electric wire strung along the inside of my woven wire fence to keep my zebra from being tempted to consider the grass on the other side. The wire was old and saggy when I took it all loose, reset the posts, restretched it and installed the electric wire. A couple of years later, I noticed that the woven wires closest to the electric strand have a clean galvanized appearance again. They were once as rusty as the rest of the fence. The impact seems to be primarily on the horizontal wires and only on the two closest, but below the electric wire. 'Slpain that one to me please!
F-I-T
01-01-2005 16:28:05
 Re: F-I-T put this in your pipe and smoke it once! in reply to Loren NC, 01-01-2005 14:28:33
First off, you know what an "Expert" is, right? It's made up of two words, "Ex" and "Spert". An "ex" is a has been, and "spert" is a drip under pressure.
I don't know.....maybe it's Zebra pee?
Seriously, depending on what power supply you are using, whether it's a pulse type, or a steady type, you could have an electrolytic effect taking place when the dew is hanging on the wire fence. They both can generate some RFI (the pulse types tend to generate more) when they fire, so you might be getting a bit of conversion with the parallel wires to the RF field. If you walked down by the fence with a pocket AM transistor radio, you might actually hear the signal.
But I think it's most likely Zebra pee.
Loren NC
01-02-2005 04:28:14
 No, I think you are wrong on this one! in reply to F-I-T, 01-01-2005 16:28:05
It couldn't be the result of any zebra action! Think about how that would feel if they peed on that electric wire! I figure it has to be some kind of electrolysis but haven't been able to come up with any explanation of how it would be working. For instance, where is it coming up with the galvanize coating to restore what was rusted away? Would it be traveling from other parts of the fence? Why only the horizonals? Why not a horizontal above the electric strand when it is closer than the one affected that is below the strand? It is just a curiosity that has me puzzled and I haven't found anyone else who has ever noticed it on their fences.
F-I-T
01-02-2005 07:23:53
 Re: No, I think you are wrong on this one! in reply to Loren NC, 01-02-2005 04:28:14
Well, see with the stripes and all, maybe zebra pee is polarized! Bewsides, I DO know how I would feel if I peed on an electric fence. Don't ask me why I know.
Anyway, and it's all guessing,
It might not be actual zinc. It might just be iron which converted first from red to black, then the black oxide sheds off to reveal pure iron metal. If you stopped the power, or removed a small section of the fence and placed it away from the electric field, you could see if and how long it took it to rust again.
I can see the horizontals for two reasons. When there is moisture present, it clings longest to to the horizontals. Also, if it IS RF energy that is affecting things, it would form a long extendended donout around the "antenna". Couple this with the moisture and you might get the field to skew or at least be most effective towards the lower elements during their period of dampness. Afterall, they don't rust when they're dry.
Loren NC
01-02-2005 09:08:07
 Interesting answers. in reply to F-I-T, 01-02-2005 07:23:53
Thanks for your thoughts. It was guessing it had something to do with induction but couldn't figure out just how. You could very well be right about it not being "regalvanized" and instead just being very clean metal. I haven't checked that. Although, now that I think about it, I had the wire turned off for probably a couple of years and I could still see the difference. Wish I had studied it more carefully before I put the power back on. Incidentally, it is a pulse charger.
Chrisfromsolitude
12-31-2004 19:27:34
Thanks for the help guys. I'll try it and let you know what I think.
