Electrolysis!!!
Jason Z in MO
12-31-2004 16:55:10
After spending hours on my feet in front of the blasting cabinet or under a hood getting sand everywhere I finally broke down and rigged up a electrolysis tank. Doesn't seem right to be able to clean down to bare metal without spending hours of labor! WOW!!!! Thank you Frank (FIT) and Henry!
Cooking the slick back cover and gear shift rod off an early styled B.
Now I need to rig up a way to clean bolts. I used to stand in front of the grinder with a wire wheel to clean all the theads! Not any more!!!
Happy New Year all!
msb
12-31-2004 18:25:55
 Re: Electrolysis!!! in reply to Jason Z in MO, 12-31-2004 16:55:10
I use an old carburetor cleaner basket.It works great.
Garland(Gman)
12-31-2004 18:16:22
Jason I've been reading you'alls comments on Electrolysis and am interested in setting up a tank. The tank does it have to be steel,plastic or whats it made of. I'll need somemore info about setting this thing up. Would it be practicle to set one up where you could set a 38' rim or cast center over in the tank? Thanks Gman
Jason Z in MO
12-31-2004 19:38:11
 Re: Electrolysis!!! in reply to Garland(Gman), 12-31-2004 18:16:22
Gman,
I set mine up based on Frank's web site. >Link
Look>Link in "restoration tips".
The tank I am using is a plastic cattle mineral tub. If you can find a tank large enough I don't see why you couldn't dip rims. If you use a metal tank you would have to be careful to insulate the tank from the positive electrode and the part you are cooking.
Frank and Henry are the experts here!
Give it a try, I think you will be pleased.
Happy New Year!
Jason
36BinMN
12-31-2004 18:15:47
third party image
That was me with the basket. Some say it shouldn't work it seems to though. This is the basket I made of 1/4" mesh.
36Bin MN
12-31-2004 18:16:46
 Re: Electrolysis!!! in reply to 36BinMN, 12-31-2004 18:15:47
sorry the pic didn't work
36BinMN
12-31-2004 18:18:12
 Re: Electrolysis!!! in reply to 36Bin MN, 12-31-2004 18:16:46
third party image
Try again
Henry J
12-31-2004 17:05:12
Jason
I have cleaned small stuff by using iron wire like the rebar tying stuff and simply give the wire how many ever twists you need to secure it and continue on to the next piece resulting in a bunch of it tied to the same wire for the vat.
I also saw a picture where a person made a wire mesh basket 9out of construction wire (the 1/2 inch square stuff) and threw all the little stuff in the basket and hooked up the basket to the lead for cleaning. He showed pictures of it working.
Jason Z in MO
12-31-2004 17:36:49
 Re: Electrolysis!!! in reply to Henry J, 12-31-2004 17:05:12
Henry,
I had thought about your suggestion of wiring a bunch together with baling wire. Will give it a shot in the morning.
I am getting about 10 amps max. My positive electrode is a piece of stainless sheet metal and an old lawn mower blade to give a little more surface area. The vat is about 20 gallons. I used about 1/2 box of washing soda and 1/2 container of lye.
Seems to be bubbling and foaming just as you discribed.
F-I-T
12-31-2004 18:12:31
 Re: Electrolysis!!! in reply to Jason Z in MO, 12-31-2004 17:36:49
Ah, Yes! The force is strong in this young one...
Soon the entire Universe will be dominated by the followers of the "Dark Side"...
