2510 Cracked Block - Need Advice
Paul2510
12-31-2004 15:59:06
My 2510D was leaking antifreeze into the crankcase, slowly. My son and I pressure tested the cooling system at 15-16 psi to see where the antifreeze was leaking into the crank. The antifreeze could be observed leaking down around the the main bearings on either side of the #3 cylinder.....Not a fast drip, very very slow about a drop per minute. I looked and looked to see if I could see the source.....I could not see anything coming from either side of the cylinder liners, inside or outside. However, with the crank still in place it was tough to see everything. Then we observed a small weep of antifreese coming through the outside of the block....on wire brushing we could see a crack in the block adjacent the #3 cylinder but could not see that it propagated very far. It appeared to have been brazed and then re-painted.
Well, thinking we had found the source we have completely dismantled the engine. The liners look very good (no pin-holes). The three o-rings look good however the one on the bottom, interfacing with the crank case oil, looked rotten or etched on cylinders 3 and 4. The other two 0-rings on cylinders 3 and 4 looked good. I could not observe any internal cracks in the block but as I understand it cracks may not be visible to the naked eye. (Oh, on tear down we observed a freeze plug partially pushed out.) On further inspection, I noted that in the block where the 0-rings interface between the block and the cylinder liner the casting surface was pitted and in one place on the #2 cylinder the casting had a pit in it that would certainly not permit the 0-ring interfacing with the antifreeze to seal....the casting had a pit in it the size of a small pea. So, was there a crack in the exterior surface of the casting and did it leak....Yes. What was the source of the antifreeze dripping into the crankcase?...a crack in the casting?....a pitted casting at the o-ring interface?....I can't be sure. Would such a slow leak indicate a crack? Any comments would be helpful.
OK, what to do??? My plan is to replace the block but in which manner. Here are the options I have developed so far. 1. Used block, ($600-$750), plus new liners and pistons ~$1400-$1550. 2. Used 219 cu. in. motor-complete, $2500-$2750. 3. New block, (~$1800), plus new liners and pistons ~$2600. 4. Short Block, ~$4200.
The crank and head look good, just need to go to machine shop for machining. The cam is below the normal spec. limit on several cams. We still need to check the balancer shafts.
I am seriously looking at options 1 and 3. Option 1 is cheaper if the block I get is good, but I am concerned about getting a block that again is pitted at the o-ring interface. Option 3 would give me a freshly machined block that is even updated slightly, e.g. newer casting number.
I plan to keep the tractor, it is in otherwise good shape, tack says 5000 hours. I would appreciate any comments, insights, suggestions.
Paul2510
Mike M
12-31-2004 16:34:47
 Re: 2510 Cracked Block - Need Advice in reply to Paul2510, 12-31-2004 15:59:06
You might want to have your block hot tanked and magnafluxed to see if it is indeed cracked or if your leak was just from a bad liner o-ring sealing area. Some of the larger engine machine shops can repair the inside lower sealing area of a block. I think it is a standard practice on certain models of cummins engines maybe even an update ? This may give you option # 5
