B Only Has 4th and 6th Gear
Gr8Bald1
12-31-2004 13:40:19
Just got the B back together and green in time for a couple of trips around the yard and onto the trailer for the ride from Louisiana to Indiana. Before she went on the trailer, tractor was operated in all gears, including reverse with no problems. After a long day of towing, went to back tractor off trailer to discover no reverse. Rolled tractor off and monkeyed with it enough to determine I have 4th gear when shifter is on the right side of the quadrant and 6th gear on the right side. It can be anywhere along the bottom (where it should be in neutral) or up and down either vertical side. BUT--if I try to put it into R or any gear besides 4th or 6th, tranny is locked up and engine dies immediately if clutch is engaged. I can't physically put shifter into the 4th gear position, it will go far enough forward but then will not move to the left to go into position. I can't get the shifter into 6th because it stops about 1/2 shifter diameter too low to be able to shove it to the left to go to the hole. My guess is the 2 forward shifter shafts are sticking together (this happened when installing the axles but I unstuck them and tried to get them to stick again but couldn't and couldn't find a reason they were sliding together in the first place). Is there anything I can do short of taking everything apart and getting my hands on the shifter shafts? I think I know the answer already but I REALLY don't care for the idea of opening things up and goofing up freshly painted things.
BushogPapa
12-31-2004 16:13:13
 Re: B Only Has 4th and 6th Gear in reply to Gr8Bald1, 12-31-2004 13:40:19
I hate to say it, but it will be easier, if you take the steering wheel off, and slide the steering shaft forward..I know, it will scratch the paint...but you want to get everything aligned in there right the 1st time... Maybe it would be a good time to oil the upper detents, and shafts, while the shift cover is off, too.. Good luck..I bet it is really pretty..!!
Ron.
Clooney
12-31-2004 15:10:40
Gr8Bald1, did you leave it in gear when you towed it on the trailer? If so it probably chucked around enough to work one of the shift rails over so your shift lever now won�t pick the shift slot up.
Probably just a simple case of pulling the trans shift cover up, then lining all the shift rails back to neutral, then bolting the cover back on with the lever in the center of the shift rail slots..
I never trailer an older Deere in gear as most of those old devils don�t have shifter interlocks, if those things get jammed in forward they are a bugger to get off the trailer..
G,d New Year ___Clooney
Gr8Bald1
12-31-2004 15:32:01
 Re: B Only Has 4th and 6th Gear in reply to Clooney , 12-31-2004 15:10:40
Yes, Sir, I did leave it in gear. I guess I'll try to CAREFULLY pull the cover up and slide it back far enough to get a peek at what's going on inside. I guess I was hoping someone had a magic trick to fixing that that didn't involve wrenches and sockets on freshly painted bolts. Thanks for the help Clooney--glad to see you back on here!
Rob
