4010's Safety Switch
JWhite
12-31-2004 11:56:28
4010 been running good since the last time it was in the shop over a year ago. The other day I went to start it and it wouldn't start, click, or make anyother noise. I tried putting the charger on and it still wouldn't do anything. I knew that a low battery would still make the starter soliniod "click" so I started looking under the dash at the safety switch. I found the switch itself still mounted on an "L" shaped bracket but the stitch does not press in all the way when I move the gears in and out of neutral. I also found a 3 inch long, 1 inch wide curved piece of metal that had 3 prongs on one end (two bent forward and the middle bent rearward) laying on the frame. Is this piece of metal the what keeps the head of the stwitch against the gear shifter? I do I fit it back in?
JWhite
12-31-2004 18:44:02
 Re: 4010's Safety Switch in reply to JWhite, 12-31-2004 11:56:28
Thanks, Got it working.
msb
12-31-2004 18:39:26
After you get that striker plate reinstalled, you might need to readjust the plastic finger so it only contacts the switch enough to trigger it.
BradB
12-31-2004 13:02:18
Yes that piece of metal goes on the switch. There is a plastic finger that pushes on the metal and then pushes the switch. That finge moves in an arch as the shifter is moved. I had to play with mine quite a while to get it working properly. Also has a little spring to it so it returns back every time.
