David, these broad problems such as she wont start are a lil tough to diagnose over the net cuz we first have to determine if the problems FIRING or TIMING or NO FUEL or LOW COMPRESSION etc. Good advice below heres a few more thoughts n opinions which may help. (A) SPARK N TIMING RELATED; 1) You say shes now "firing", so the next question is IS EACH PLUG FIRING ON THE COMPRESION POWER STROKE TDC???? If the distributors in and timed right remove the plugs and verify that: The plug on the left cylinder (via the leading cap tower) fires when the piston is at TDC on its Compression Power Stroke TDC and then 180 degrees of crankshaft rotation (thats 90 degrees of distributor rotation) later, the right cylinder plug (via the lagging cap tower)fires when that piston is at TDC on its Compression Power Stroke. 2) Insure BOTH plugs are producing a good visible BLUE and not a faint thin wimpy yellow spark. If they appear any fouled or carboned or blackened up start with a new set of plugs. (B) FUEL RELATED; The carbs bowl has to be filled with fresh clean water free gas. If its drain is opened and the gas valves or an auto fuel shut off manually over ridden open (loosen top knurled nut and depress n hold down) gas should run out continuous. Do you have the auto shut off sediemnt bowl assembly and is it working and can you manually open it??? On my 620 there was a choke problem located underneath the round assembly where the choke rod connects to the choke butterfly plate. The rod could be pulled externally but the actual choke butterfly plate wasnt closing fully cuz of the coil like spring under the cover. If shes not getting choked you wotn get much smoke or vapor out the stack. My 620 in the winter takes full choke a few seconds till I see some smoke/vapor out the stack, then I depress the rod n open the choke n she fires. However, when the choke wasnt working right she refused to winter start. SUMMARY: You gotta have a good blue spark out of good plugs at each compression TDC,,,,, ,,fresh clean water free gas,,,,, ,working choke,,,,, ,,,,compression,,,,, , n she oughta start. Checkl the spark n chole n see if youre ever getitgn any smoke/vapor out the stack n let us know your findings n post back any more questions. Good Luck God Bless n have a safe happy n blessed New Year. John T in Indiana
