Shuttle shift
Ken in Mich
12-30-2004 19:27:40
I notice some tractors are listed with a "shuttle shift" what is this? Thanks, Ken
Jim Nauert
12-31-2004 17:11:14
 Re: Shuttle shift in reply to Ken in Mich, 12-30-2004 19:27:40
My 420w has a reverser it is very handy when you use a post hole digger. Not only does it reverse the direction but also reverses the pto so if the post hole digger gets hung up you can just back it out.
leon
12-31-2004 14:05:50
I think the most commonly used terminology is that moving a single shift lever straight back and/or forward, combined with clutching, is a shuttle shift or shuttle reverser. If you move a little lever forward and back (it being connected to to the transmission through electrics or hydraulics) without using the clutch to get forward/reverse, that's a power reverser. Deere now usually makes reverse 15 to 25% faster than the corresponding forward gear on either a power or shuttle reverser. That helps loader cycle efficiency.
Bob
12-30-2004 19:34:42
It is a transmision that allows quick changes from reverse to forward, usually at the same speed, at the flip of a lever, rather than having to move a shift sector though the gears.
It's very usefull for FEL work.
TB SCOTT
12-31-2004 05:42:57
 Re: Shuttle shift in reply to Bob, 12-30-2004 19:34:42
I thought that was a direction reverser. The shuttle shift I thought was when you still had to move the shift lever, but it was in a straight line forward and backward but still had to clutch.
Ken in Mich
01-01-2005 04:05:18
 Re: Shuttle shift in reply to TB SCOTT, 12-31-2004 05:42:57
Thanks Guys, I figured that was what it was, but I've been wrong before.
I bought a JD500 diesel backhoe, I havent got it trucked in yet, but the owner said it had a shuttle shift.
I lurk on this forum a lot, but seldom post. I have learned a lot here. Ken
