JD 50 carb
rej
12-30-2004 17:19:21
The carb bowl attaching nut on my 50 has a hole in it. Is it suppose to be like this for adjusting the load screw without removing the bowl. Also the threaded area that the attaching nut screws onto has a small slot in it were it attaches to the base of the carb, is this correct. Any help appreciated. Thanks
Clooney
12-30-2004 17:41:46
 Re: JD 50 carb in reply to rej, 12-30-2004 17:19:21
third party image
A picture is worth a lot of writing.. It sounds like you understand it..
Clooney
rej
12-30-2004 17:55:22
 Re: JD 50 carb in reply to Clooney , 12-30-2004 17:41:46
Clooney, I also have a small leak and it's dripping through the hole on the bowl attaching nut. If i use a nut without a hole would this cause some sort of back-up or flooding?
Clooney
12-30-2004 18:59:19
 Re: JD 50 carb in reply to rej, 12-30-2004 17:55:22
Rej, you ask...
Quote:-- " If I use a nut without a hole would this cause some sort of back-up or flooding?�
--I haven�t ever tried that so don�t know if it will clear.. It won�t hurt the carb operation or cause a problem other than it will not allow a load needle adjustment..
The usual float bowl fuel leak places I find on those 50 Duplex carbs is at or around the rubber �O� ring on that load needle or between that bottom cap nut & the float bowl..
I would suggest you try a new load needle �O� ring, then add a second stem nut gasket between that bottom nut & float bowl [the original & correct bottom bowl nut gasket is inside the float bowl between the bowl & stem bottom..
I know it�s difficult to work in there as you have little room so using an off-set screwdriver or little screw driver bit & flat ratchet helps..
Clooney
rej
12-30-2004 20:38:00
 Re: JD 50 carb in reply to Clooney , 12-30-2004 18:59:19
Thanks Clooney, i'll work on it some more tomorrow and see what happens. rej
