70 gas left govenor housing
GORDON R
12-30-2004 17:12:30
What can I expect when I remove left govenor end when I remove it to replace gasket? Will everything fly out? Thanks in advance
Clooney
12-30-2004 17:28:04
 Re: 70 gas left govenor housing in reply to GORDON R, 12-30-2004 17:12:30
GORDON R, nothing should �fly out� but that shaft is spring loaded & will push out a little..
There is a chance you could loose a ball or two from the L/H bearing if there is a lot of wear on that bearing.. Problem is, those balls will fall down into to the governor or could even go as far as the engine crankcase..
Remember that gasket is also an adjustment shim so the thickness MUST be kept the same or you risk fan gear damage..
One more thing, remove the distributor before pulling that L/H cover as it could become jammed or damaged if that governor shaft is pushed back in place with the distributor still in place.
Clooney
