2010 hyd.
davids
12-30-2004 16:41:35
On my 2010 JD the aux. hyd. valve has started to leak. I never use it and am going to remove it. What ports do I neeed to plug off or do I need to install a return line of some kind? Thanks,Davids
HTR
12-30-2004 18:19:41
 Re: 2010 hyd. in reply to davids, 12-30-2004 16:41:35
You will need the adapter piece that came on the tractors, less remote valve. Depending on the serial number, there were two different ones. The early tractors had a small housing with two bolts. The later tractors had a round adapter with three bolts. That will probably be a salvage yard item.
davids
12-30-2004 19:39:37
 Re: 2010 hyd. in reply to HTR, 12-30-2004 18:19:41
Does anyone has a outlet for one? Thanks, David
Bob
12-30-2004 21:00:28
 Re: 2010 hyd. in reply to davids, 12-30-2004 19:39:37
Could the valve be repaired with an "O" ring or two? Having the valve probably adds value to the tractor.
Otherwise, how about posting on the adds? There's probably someone out there with a plate that would be glad to have a valve, even if it needed some seals!
