GP carb
Lynda
12-30-2004 16:18:57
My husband bought me 2 carbs for my gp the first is a Ensign AC174r. The second looks the exact same with the same casting #s but it doesn"t have a tube on the side and the idle adjuster on the oppisite side
Duane Larson
12-30-2004 20:11:16
 Re: GP carb in reply to Lynda, 12-30-2004 16:18:57
Lynda,
There were (at least) three different versions of the AC174R carb. The first (and rarest) was used on the C and had an "internal" tube (the bulge can be seen on the side) with the water feed inlet on the side. The second version had an external, bent tube on the side with the choke lever, and the water feed inlet on the bottom. The third version was back to an internal tube, again the water feed inlet was on the bottom.
I'm not sure about the idle adjustment - do you mean it is just not there on the side with the choke lever near the throttle plate shaft? Or is it somewhere else?
Lynda
12-31-2004 10:19:53
 Re: GP carb in reply to Duane Larson, 12-30-2004 20:11:16
The idle adjuster is on the oppisite side of the choke lever
Duane Larson
01-01-2005 07:12:55
 Re: GP carb in reply to Lynda, 12-31-2004 10:19:53
Lynda,
Hmmm - I'll have to check on this as I don't recall a AC174R with that configuration. It may be an Ensign B for some other tractor and that will take some looking. I'll post back, or if you provide your email address I'll send what I find to you.
