TommyJD, this might be the archive post you have already looked at.. If not this is a Dubuque distributor set-up I wrote for a fellow a while back & should cover your distributor installation & timing from the beginning to the end.. ****,you really need to get it lined back up so both plugs spark as those corresponding cylinders are at TDC ON compression.. ~That 420 has a � speed distributor so it is easy to get it to fire only one cylinder then not line up with the next one as the spark rotor only travels 1/4 turn between # 1 cylinder firing & #2 cylinder firing.. ~Pull the little timing cover from the bell housing,, then remove the spark plugs,, then rotate the engine in the running direction [a hand crank works best but you can put it in high gear & roll the tractor to do it also] until the front cylinder just starts to make compression,, then look in the timing window & continue rolling the engine until the DC mark lines up in the center of the timing hole.. At that time the distributor rotor should be pointing at the front plug cap tower contact [inside the cap] & the distributor points should just be starting to open [look closely to make sure they are just OPENING & NOT CLOSING].. Then roll the engine � turn more in the running direction [either put a mark on the front engine pulley or use a piece of wire in the #2 plug hole to feel for the piston to be at TDC].. At that time the spark rotor should line up with the other cap tower contact [inside the cap] & again the points should just be starting to OPEN.. ~Once you do the above & get it to fire on BOTH cylinders, you need to set the ign timing.. To do that,, bring the engine back to DC [compression] on #1 cylinder,, then turn the ign switch on,, then rotate the distributor body in the running direction a ways,, then rotate the distributor in the non turning direction [backwards] until you see a spark on the #1 spark plug [plug removed & laying on the engine block].. Added information--- When that distributor is in correctly the power wire stud will by pointing out away from the engine & slightly forward towards the generator & the plug wires will both be towards the engine block. You might want to print this out & take it out to the tractor with you.. Clooney
