4630 compression test
Patrick N
12-30-2004 13:39:59
I have a late model 4630. I want to do a compression test and cannot find the pressure information for this engine.
Heat Houser
12-31-2004 03:29:23
 Re: 4630 compression test in reply to Patrick N, 12-30-2004 13:39:59
New Engine, it should be approx:
Crank speed 200-250 RPM Compression pressure 330-370 psi (23.21- 22.04 kg/cm)
Pressure given was taken at 1000 feet above sea level. A 3.6% reduction in gauge pressure will result for each additional 100 feet of altitude.
FYI Waterloo Iowa is right at 1000 feet above sea level. The above was taken from my Tech manual, TM-1172 (Jul-79)
Patrick N
01-02-2005 05:58:47
 Re: 4630 compression test in reply to Heat Houser, 12-31-2004 03:29:23
thank you for the information!!!!! !
twopop
12-30-2004 16:19:08
somewhere in the area of 350 to 400 psi. diesel wont burn below 270 psi
