F.I.T. - Electrolysis question
Jason Z in MO
12-30-2004 08:10:23
Frank,
Hope you are having a good holiday! I am getting ready to mix up an electrolysis bath. Your web site says one tablespoon per gallon of water. The lye and washing soda can be mixed. Do you use 1/2 tablespoon of each per gallon?
You also said when the parts are cooking, it off gasses hydrogen and oxygen. Should the bath be set up outside? Hydrogen and oxygen sounds like an explosive mix... My shop is 40-60 with lots of cubic feet of air but I do heat with wood.
I was at an auction a few months ago and picked up a commercial 6 volt battery charger. It will run 100 amps but is current limiting so I thought I would try it around 10-20 amps.
Thank you for your thoughts and suggestions!
Happy New Year!
[email protected]
Bob seND
12-30-2004 14:15:20
 Re: F.I.T. - Electrolysis question in reply to Jason Z in MO, 12-30-2004 08:10:23
Jason,
Be sure to wear eye protection when working with lye or any strongly basic substance. Any splash in the eye is likely to melt your cornea. Acid is not
nearly as dangerous.
Bob seND
Jason Z in MO
12-31-2004 08:22:07
 Re: F.I.T. - Electrolysis question in reply to Bob seND, 12-30-2004 14:15:20
I will follow your suggestion to the letter!
Henry J
12-30-2004 11:12:04
Jason
If you got some scrap stainless steel laying around or know where to scrounge some it sure will take a lot of the work out of the red side getting gunged up, needing cleaning, and eaten away. I think Frank mentioned this on his site, but thought I would echo since I tried both ways.
Jason Z in MO
12-30-2004 11:48:00
 Re: F.I.T. - Electrolysis question in reply to Henry J, 12-30-2004 11:12:04
Thanks for the tip, I will try to scrounge some. I don't think I have any on had.
F-I-T
12-30-2004 08:24:04
Jason:
Gotta run, but here's the quick version:
...Your web site says one tablespoon per gallon of water. The lye and washing soda can be mixed. Do you use 1/2 tablespoon of each per gallon?
Doesn't matter. either soda or lkye or both. It rained hard the other day, so when I put parts in last might it was low on amps, so I just sprinkled lye crystals on the surface (they dissolve fast by themsleves) and watched the current come up. Then I took a paddle and stirred the tank and it came up some more and I went to bed. Pretty scientific, huh?
...You also said when the parts are cooking, it off gasses hydrogen and oxygen. Should the bath be set up outside? Hydrogen and oxygen sounds like an explosive mix... My shop is 40-60 with lots of cubic feet of air but I do heat with wood.
It will put off about the same amount of hydrogen as a charging battery at the same current. I keep mine out side only because I drip and dribble the liquid. When I build my big shop, I'll keep in inside under the work bench. I'd put it outside. If you ever had a tank crack and leak you'll be glad it's outside. Just hose it down and start again.
...I was at an auction a few months ago and picked up a commercial 6 volt battery charger. It will run 100 amps but is current limiting so I thought I would try it around 10-20 amps.
That's fine. I use 5 volts and at 32* it's cooking just fine.
Frank
Jason Z in MO
12-30-2004 13:34:18
 Re: F.I.T. - Electrolysis question in reply to F-I-T, 12-30-2004 08:24:04
Frank / Henry,
Thanks for your suggestions! I am gonna get something cooking this weekend!
Do I need to be concerned about the solution freezing?
Henry J
12-30-2004 16:49:00
 Re: F.I.T. - Electrolysis question in reply to Jason Z in MO, 12-30-2004 13:34:18
Jason
It may be difficult to get Frank's vat to freeze down there in FL. There has been some discussion on this. I did not get scientific, but my cooker froze up quite readily when not in use.
Also, I tried to kick it back on one day after it froze up with about 3/8 inches of ice. It took off at what appeared to be a normal rate under the ice.
But dang, my fingers got cold, I am outta there for the winter.
SC and FL here I come
Happy new year
Dave in Ohio
12-31-2004 10:52:43
 Re: F.I.T. - Electrolysis question in reply to Henry J, 12-30-2004 16:49:00
FIT, I have two brass tag B's and an unstyled A at various stages from ready to paint to still junk. I'm coming to Fla. Sunday for a month to spend some of that old Yankee money. Hope there is a little left for old John Deere when I get home.
Dave
F-I-T
12-31-2004 12:35:53
 Re: F.I.T. - Electrolysis question in reply to Dave in Ohio, 12-31-2004 10:52:43
Oh no! We want you should spend it all! That's how we get all those "deals" on tractors down here!
HA!
F-I-T
12-30-2004 19:14:52
Henry,
Actually my tank had ice on it this week. :(
The worst part about it freezing is how do you get the parts in there!?!
Hurry down to Florida. You know our unofficial state motto?
"Welcome to Florida. Spend your money and go home!"
Jason Z in MO
12-31-2004 08:20:26
 Re: F.I.T. - Electrolysis question in reply to F-I-T, 12-30-2004 19:14:52
Well you boys have a good time in Florida while I ride it out in Mid-MO! By the way, we have 60+ deg weather today...
Who thinks there isn't any global warming???
Have a great time down there!!!!
