Indydirt......come in
txblu
12-30-2004 05:07:27
John,
Need your help. Beins that someone we both know chose to keep the results of their hard work, this dude stumbled across a 4230 that he couldn't resist.
What I need to do is space out the wheels. They are set up for 30" row crop and are against the fenders. Don't know about you but that's too tall and narrow for this dude. Afraid of falling over and crud on the tires will get stuck between them and the fenders.
As usual,
Thanks,
Mark
R. John Johnson
12-30-2004 07:52:12
 Re: Indydirt......come in in reply to txblu, 12-30-2004 05:07:27
Congrats Mark!
That should be a perfect match for that 530 baler. Next thing you know all the neighbors will be wanting you to bale hay for them. IDF gave good advise on adjusting the rear wheels. It is the same procedure as used on the New Generation Deeres, so there is some additional info, and some controversy, on this subject in the archives.
John
txblu
12-30-2004 10:00:56
 Re: Indydirt......come in in reply to R. John Johnson, 12-30-2004 07:52:12
R. John,
Funny how things happen. Really wanted both but wasn't shopping, per se. Accidentally saw the 530 and the 1209 swather too (my rubbernecking problem you know). Then I got to looking at tongue weights and other things and then looked at my 4010..... gonna be workin you baby.
Then, was going to town to get tires for the 1209. Had to go to my special farm tire dealer (has everything) as they were 26x12x12 and was told that they are getting scarce. On the way, passed by this "other" guy's place who goes all over finding these relics and redoing them and he had a couple of greens sitting there, amongst some white and red.
Since the gate was open, which it rarely is, my truck just whipped in there before I knew what was happening.
Had this one and a 4430. Drove both and liked this one better.
That night I talked to the wife about it and guilt feelings and all and she was very supportive.....bad (er ah good) mistake.
Next day I was going to town again and she wanted to come along. Went down the same road and truck did the same thing. Looked at others (Case 2290 for one; $7k cheaper) and decided that if I was going to do it I was going to do it right.
Bank just happened to be about a mile down the road. She followed me home..... .the rest is history.
Mark
R. John Johnson
12-30-2004 18:23:57
 Re: Indydirt......come in in reply to txblu, 12-30-2004 10:00:56
Mark
I resemble that remark about rubbernecking! LOL.
Thats how I found that NH664 so fast when the old Vermeer burned last fall. One of these days I would like to get a 4230 or 4030 to run her, but finances are a little to tight right now. Oh well , the 4010 still does alright. All things in good time.
John
txblu
01-01-2005 07:00:34
 Re: Indydirt......come in in reply to R. John Johnson, 12-30-2004 18:23:57
Trust me. You speak the truth. Just need patience. (I'm just now finding out.....worth the wait.)
Mark
Indydirtfarmer
12-30-2004 06:31:43
That's a REAL good tractor! They're more or less an upgraded, modernized 4020. All the good parts of a 4020 with the rough edges polished off!
I'm assuming you're wanting to know how to adjust the rack-and-pinion rear wheels.
There is a "rack bolt" that runs at 90* to the axle. Jack up the side you're working with, and get that bolt on the top, parallel with the ground. Then, turn the THREE wedge bolts out. (loosen them at least 3 or 4 turns) Then, start cranking the TWO longer bolts IN. Use a cheater bar. The bigger the better. Get them as tight as you can muster. If that doesn't break the wedges loose, strike the end of the axle as hard as you can, with the biggest hammer you can swing. Tighten the TWO bolts again. Hammer again. At some point, you will see the wedges release. Then you turn the rack-and-pinion bolt to move the wheels in or out. You might want to spray a good penertating oil on everything before AND after moving the wheels.
Once you get them where you want, loosen the TWO longer bolts. (At least 3 or 4 turns) Then tighten the THREE wedge lock bolts. get them REAL tight. After using the tractor for a while, go back and tighten them again.
Get yourself all the manuals to your tractor. (All the above is described in them) Get the owners manual, technical manual, and parts manual. They'll pay for themselves in short order.
Good luck with your new purchase. Glad to see you in the GREEN fold now!
The Mothership will be visiting you shortly! John
txblu
12-30-2004 07:44:26
 Re: Indydirt......come in in reply to Indydirtfarmer, 12-30-2004 06:31:43
Thanks man. Fast reply and great info. I think I understand what you said. Manuals are a must and will be incoming in short order.
This little babe really had 3900 hrs on it. Checked the brake pedals, steering linkage, pto shaft and drawbar to prove it. Guy put a real nice paint job on it, new rubber, redid the cab and put a new 134 AC compressor and system in. I have wanted one of these series (42XX, 44XX)with cab, since moving out here 25 yrs ago.
Belonged to the bro-in-law of the guy who fixed it up. Used it to mow pastures. Seems he'd buy acerage, clean it up, fence it and put a barn on it. Then sell it and go after another.
Will be in touch. Maybe I'll have to change my handle as I now have more green on the lot than blue. How does "txgreen" sound? Or maybe "txblugrn" Grin
Thanks again.
Mark
