310A SHIFTING PROBLEM
GARY ATTEBERY
12-29-2004 12:36:18
MY 310A WILL NOT SHIFT OUT OF FORWARD. FOR A WHILE, IT DID SHIFT BUT VERY HARD, AND WHEN IT DID, IT ALMOST FELT LIKE IT WAS BENDING A SHAFT OR SOMETHING. ANY WAY, I WOULD APPRECIATE ANY HELP.
Jonathan in MA
12-29-2004 15:53:25
 Re: 310A SHIFTING PROBLEM in reply to GARY ATTEBERY, 12-29-2004 12:36:18
The linkage passes thru the dash . Then attaches to a cross-shaft that passes thru a tube (probably the problem area) that crosses the top of the reverser housing. then drops down to the reverser control valve. Remove the shift linkage at the reverser valve to determine if the binding is the linkage or internal in the valve. The valve lever should move easily by hand, with definite detents. If its binding in that cross tube, it can be quite time consuming to free up with sparay lube etc...
george eaves
10-02-2005 13:08:45
 Re: 310A SHIFTING PROBLEM in reply to Jonathan in MA, 12-29-2004 15:53:25
I have a JD 310A that will not shift out of neutral. The tractor was working just fine and I pulled up to dump the loader and when I went to back up, it stayed in neutral. Hyd oil level is good, clutch feels good, transmission and transfer case appears to shift correctly. I suspect something awry with the reverser. All hydrolics work fine. Any ideas?
gary attebery
12-29-2004 16:21:17
jonathan. i need to get ahold of you. you helped me last spring and i need to pay you. gary
