choke postion on a tsx 688
bgiese
12-29-2004 12:26:42
I have my carb from my 420 apart and I have managed to forget which postion the choke plate goes in, does the spring loaded flapper plate go toward the air intake side or toward the nozzle side, it would make sense to have it on the nozzle side to prevent you from completely closing off the air,thanks for the help
Clooney
12-29-2004 12:42:30
 Re: choke postion on a tsx 688 in reply to bgiese, 12-29-2004 12:26:42
bgiese, that spring loaded trap door gets installed so it opens in towards the carb center.. It allows the intake air to open it when the choke plate is closed.. That�s the same on all TSX carbs.
BUT..
On some TSX carbs that trap door goes towards the top of the carb & on others it goes towards the bottom. Unfortunately I don�t remember whether up or down on the 688.. I list a lot of TSX carbs for choke plate trap door direction but the 688 isn�t in my set-up book..
Clooney
