60 radiator core
old bones
12-28-2004 19:18:56
am replacine radiator core in 1954 60. would appreciate a little experienced advice on a few questions. am going with aftermarket ($130) versus JD ($300). should i use paper gaskets with sealant, or is a rubber gasket available for the core? parts man hadn't heard of rubber gaskets, but radiator shop said to use them.
how well does the upper water pipe come out of the upper and lower castings? the shop manual shows o-ring type seals at each end of the pipe, inside the castings. been my experience with other similar jobs that the pipe will probably be rusted/pitted where it comes in contact with the o-rings and need replacing,too, but will determine that when i get it out.
thanks, in advance
old bones
Jonathan Anders
12-29-2004 07:02:24
 Re: 60 radiator core in reply to old bones, 12-28-2004 19:18:56
Bones,
All of the folk I know have used the paper gaskets with Permatex aviation gasket sealer. It is very tacky and non-hardening and works great. I have also found that if you use it on the upper and lower water pipe gaskets, and you forget to put the power steering pump in place first (I did), the gaskets come back apart easily and will reseal just fine without applying anymore sealant.
Mike M
12-29-2004 06:58:27
My first one of these radiators I did was back around 1978 used the gaskets from Deere.Never again did I use Deere gaskets as they are too thin. I had to redo that one and make my own out of thick gasket material,paper or even a good cork rubber has worked far better over the years.
Use your favorite brand of sealer if you want.If your tanks are real bad I have had some resurfaced at the local auto machine shop.They have a large belt sander to surface heads and this works great on these large tanks that are hard to hold. On those tractors with the o-rings holding in the pipes if you get one that won't pull out just heat the casting up where the o-ring is with a torch and it will burn up letting the pipe come out easy.After cleaning up everything they are very easy to assemble if you smear silicone sealer all over the o-ring and on the pipe it lets them slide right in and fills in the pits and seals them when they dry.An added plus is that if you every disassemble it at a later date they pull right apart.
F-I-T
12-29-2004 06:35:33
third party image
The most recent one that I re-cored was in my 70 Diesel, and the job pretty much went like those here have described it. I did not have the degree of pits in the tanks that I have had on others, so I opted for my age old favorite sealer, "Permatex".
I didn't have too many problems, but I did break off one bolt and two 3/8 studs that are in the top row, fan side. They didn't even feel tough from the start. I think they were just that weak.
If you know the core is going to be scrapped, you can really go at it. I like to use a propane torch to pre-heat the bolts, and still I broke three. Warm the castings all over of course, then concentrate on the one or two you're going to remove first. Although I have acetylene available, I find on a thin casting, propane is about all you should need.
I cleaned all the castings in my electrolysis bath, and it removed a bunch of flakey rust (I mean it would have filled a large zip-lock bag !). If you can't use electrolysis, try to get the upper and lower tanks cleaned with a grit blaster, a hot tank, or at least rap them with a hammer a few times. You'll be surprised how much stuff comes out.
I was lucky enough to weld a nut on all three stubs, heated the area with propane, and two came right out. The third one needed more heat, and I had to resort to my acetylene torch on that one. Don't know why it was so stubborn.
Then I chased all the holes with a tap.
I sat the lower tank on the saw horse, put on a thin coat of Permatex Form-a-gasket (the brushable kind, just a tad thicker than gasker shellac), then the gasket, then another thin coat of permatex.
I put a small swipe of Nev-R-Seez on the first few threads of all the bolts to protect them from freezing up again. I tried to tighten all the fasteners evenly, and they all felt solid.
It was a pretty easy assembly.
On the upper and lower water pipes, that was probably the worst job I have ever encountered on a two cylinder.
I used exhaust pipe for both the upper and lower radiator replacement pipes on my 70D. Getting them together can be a test of wills, but it can be done.
When you get ready to push it all together, be sure and have 3 or 4 extra of those large o-rings on hand, because you will slice a couple of them.
Search back through the messages and you find many helpful hints. I used the "Insert parallel Shims from an old paint can" method and it worked well for me both times.
I was going to consider stainless, but the first pipes lasted 50 years, and I was able to find the correct size at the local auto parts store.
Frank-in-Tallahassee
F-I-T
12-29-2004 06:35:32
third party image
JD G GUY
12-28-2004 23:51:27
i am currently in the process of recoring the radiator on my G, i bought the "aftermarket" core through the JD dealer paid about 160 i think. was told it is made by some company in ireland, and everything seems as though it is very high quality but like was said some bolt holes dont line up perfectly. i think you would be ok with the aftermarket.
Clooney
12-28-2004 20:43:08
old bones,
Your first hurdle will be getting that water pipe out without damage [patience, heat, twisting, & maybe a hacksaw & new pipe]..It will probably end up with pin holes in it anyhow [most do]..
Your next hurdle will be getting that radiator apart without breaking all those bolts.. I usually get a new bolt kit from �Correct Connection�.. You can spend a lot of time trying to get those bolts out, you will most certainly break a few� You can use heat, pounding on them, an impact wrench, penetrating oil, & will still probably break some.. I usually just twist on them & they either come out or break off.. Then I use a L/H drill bit & a steady hand & drill them out.. Over the years I have found it faster to just break them & drill them out opposed to piddling with them for hours or even days..
Your next hurdle will be that cheap radiator core probably won�t fit exactly right [usually some of the bolt holes won�t line up].. Just match them the best you can then drill the non fitters to match the tanks..
Now on the tanks & gaskets,, Just use the production tank gaskets.. On the tanks I usually find the flattest part of concrete in my shop or on my driveway & use that to surface the tanks to be as flat as possible,, keep turning the tanks as you move then back & forth on the concrete [my wife hates it when I use the driveway as it leaves marks for about a year].. Once the tanks are fairly flat they will probably still have pits in them so I like to use Lock-Tite 518 gasket reinforcement on the gaskets.. That not only fills in the pits but also stiffens the gaskets & prevents any gasket degradation & blow-out later on. That 518 is an anaerobic sealant & dries to plastic like hardness where the gaskets fit but remains soft where there is no gasket to metal contact.. It will also fill to about .015�-.018� pits & still harden correctly.. If you cant find 518 use Loc-Tite 515 [or equivalent]..
There is much more that could probably be written but this will get you started..
Just start the job then post back with any questions when they pop up [you will have some I�m sure]..
Clooney
John T
12-28-2004 19:51:46
Old, last one we did we used the regular thick paper type gasket (seems like we got it from Mother Deere) and shes held fine, but more than the gasket type, I think the secret is we clean/buff/polish (and flatten as necessary) the core till she shines and then the tank surfaces and use sealant and try to tighten the bolts down in an even pattern. As I recall the tank surfaces were pitted some but a lot of patience and buffing got them fairly smooth and less pitted which made for a good seal.
Get the surfaces clean dry n smooth and I dont think you will have any tank/core problems and we use wire brushes and sandpaper etc. to also smooth/buff/polish the corrosion and pitting on the water pipes plus install new o rings and use lithium grease so things go back together smooth and not roll any o rings out of place.
Good Luck God Bless n Happy New Year
John T in Indiana
gathje
12-28-2004 19:41:00
I used the paper gaskets on my 50 and 60 .Got them from jd dealer.used lots of copper coat sealer on the iron and the gasket .Put all new bolts in.Took old bolts out using a tourch at times.Put all the iron parts in the lye water solution with the batery charger set up to clean .Used the after market radiator too .Looks real good.Held just fine on 60 2 years now.Don`t know if you ever used that lye water set up to clean old iron .Works real good.
Slywuf
11-11-2005 07:03:01
 Re: 60 radiator core in reply to gathje, 12-28-2004 19:41:00
Hay Gathje - can you send me the details of that lye water cleaning method you were talking about for cleaning iron parts? I'm not familiar with it. Thanks.
