Cylinder compression
Larry E
12-28-2004 18:41:00
MT JD I would like to know ,what is cylinder compression.I spent about$100 on books and cannot find in any. Have to buy three books to get all information and still no good.
Thanks
Duane Larson
12-29-2004 17:22:19
 Re: Cylinder compression in reply to Larry E, 12-28-2004 18:41:00
Larry E,
The JD Field Service Bulletin 259 gives 110 psi for the gasoline engine and 85 psi for the all-fuel engine. These pressures are measured at cranking speed with a fully charged battery, the plugs removed, and throttle wide open.
Earl S.
12-28-2004 19:29:07
Larry,MT- 6.0-1 comp ratio comparing to 50&70 with 6.1-1 best guess around 105 -110 . Have you tried wet test or cyl leak down?? Earl
