L problems
Jarrod
12-28-2004 15:34:45
I have 2 problems with my JD L. 1st is I can't seem to get it to run without the choke being on about half way. I've had the carb apart, cleaned, new kit, set float level to level, new throttle shaft. Still no better. Any ideas? 2nd, I can't seem to get the clutch to completely release. I had the engine out to check on the rear leak. I think I got that taken care of. Anyhow I put the flywheel and clutch back on then installed the engine back in the tractor. Well, after getting everything hooked back up I pushed in the clutch to put it in gear and go for a drive. Unfortunatly, The driveshaft wouldn't stop turning and it grinds when you try to put it in gear. So, I pulled it all apart and looked at the fingers on the presssure plate. Two measured 1" and one measured 1 1/8". I set them all to 1" and also looked at the disc to see if there was something else. Didn't see nothing so back together again. Started it, pushed in the clutch and the drivesaft almost completely stopped. OK I can live with that. But after driving it started to do the same thing again. What do I do? Install a new pressure plate and disc and hope? If anybody has any ideas let me know I hate taking things apart more than once for the same problem. This will be 3!!!!
Cialis
12-29-2004 19:14:06
 Cialis A href=http://www.discount-cialis-rx.com - in reply to Jarrod, 12-28-2004 15:34:45
third party image
Hi
Duane Larson
12-29-2004 17:43:11
 Re: L problems in reply to Jarrod, 12-28-2004 15:34:45
Jarrod,
Regarding your carburetor problem, is your problem mainly when the tractor is idling or put under a load? If it is at idling, did you remove the idle jet - it is the one at an angle in the top half of the carb? The passage under the jet can get plugged and make the idle system inefficient or inoperable at worst. In that case the fuel at idle would have to come from the load circuit, and choking down the system will create enough pressure difference to get the load system to feed some fuel.
If you do need to remove the idle jet, be careful as turning too hard will spread the screwdriver slot in the jet and cause it to dig into the surrounding cast iron - then it gets harder to remove. Flush everything good first with water and air, then apply some heat to the idle jet and let it cool - it should come right out. Then clean underneath it with a small wire or spray carb cleaner - or preferably a bead blaster until fluid comes out the idle holes above the venturi.
Mike M
12-29-2004 07:09:28
Your clutch problem sounds similar to the one I just had on an LA model. After replaceing clutch and throwout bearing and rebuilding the clutch housing I didn't put in a new pilot bushing as it looked good ? Lubed it up and used it.I also figured if it was worn it would loosen up and work better ? I was just switching engines and everything worked before.Well I ended up takeing it back apart and putting in a NEW pilot bushing problem solved.I would of never reused a pilot bearing but somehow I thought a bushing I could get away with. HA ! it jumped up and bit me in the butt.
Bob
12-28-2004 16:54:27
There are several passages in the bottom of the lower carburetor body that are not apparent to the casual observer. Most likely, something is gummed up down there. Soaking in industrial strength carburetor cleaner may help, or the passages may have to be cleaned with a wire or a tiny drill bit, in extreme cases. (Notice, I said CLEANED, NOT drilled oversize!)
The clutch pressure plate may be warped, or the lined clutch disc may be warped (I've learned to slip them over the tranny shaft, and give them a spin before assembly, to see if there is any wobble). Also, the lined disc may be damaged so it is thicker in some areas due to bad rivets, or rivets pulling through the lining, or the flat metal "backbone" of the plate, between the inings may have cracks, or damage.
Usually, there is a "front" and a "back" to the lined plates, and puttting them in the wrong way will make for improper releasing, too.
It is important, too, that the faces of the flywheel and the pressure plate are true, and not warped or cracked, or deeply grooved.
Deeredale
12-28-2004 19:50:27
 Re: L problems in reply to Bob, 12-28-2004 16:54:27
I bet the high speed jet under the main nozzle is partially plugged. As for the clutch, The Hercules is known for clutch problems. The main thing is there was never enough travel in the clutch rod. We have installed 1/16" thick washers under each bolt of the pressure plate in the past. This will give more travel & better release.
Larry D.
12-29-2004 11:35:47
 Re: L problems in reply to Deeredale, 12-28-2004 19:50:27
As far as Carb Cleaning Products, USE GREASED LIGHT"nin found at Wal-mart, Had a Gummy carb that Even carburetor Cleaner wouldn"t touch, those.... Brass jets came out looking like a NEW Penny!!
cheap auto insurance
09-28-2005 22:03:07
 cheap auto insurance in reply to Larry D., 12-29-2004 11:35:47
third party image
Everyone should get car insurance quotes so get your online car insurance with a great auto insurance quote
Debt Consolidation
07-08-2005 10:12:55
 debt-consolidation a href=http://www.debt-x.com de in reply to Larry D., 12-29-2004 11:35:47
third party image
Visit us! We would love to see you!
debt consolidation bad credit debt consolidation business debt consolidate debt consumer debt counseling credit card debt consolidation credit card debt credit debt debt consolidation loan debt consolidation services debt consolidation debt counseling debt elimination debt free debt help debt loan debt management debt reduction debt relief debt settlement debt solution debt eliminate credit card debt free debt consolidation get out of debt personal debt student loan debt bill consolidation Debt Consolidation Mortgage Refinancing Second Mortgage Mortgage Loan Home Mortgage Mortgage Quote Credit Cards Credit Card Application Online Credit Card Application Apply for a Credit Card Car Insurance Car Insurance Quote Auto Insurance Health Insurance Life Insurance Home Insurance Travel Insurance credit card application Cialis Phentermine Cialis Adipex Levitra hgh generic cialis Darvon Lunesta Darvocet Hydrocodone Lorcet Vicodin Vicoprofen Lortab Online Pharmacy
Link
