318 J D garden tractor smokes
J D Green
12-27-2004 19:42:18
My 318 has a onan engine that smokes alot when I hit a bump.It is not over full on oil,the air filter has been replaced.It will use about 1 pint of oil in 1 hour.It runs well with good power. HELP ! Thanks JD Green
nc jd guy
12-31-2004 14:46:54
 Re: 318 J D garden tractor smokes in reply to J D Green, 12-27-2004 19:42:18
J D Green -- post your e-mail address and I will see if I can help you out. Thanks, Ray
Gerald J.
12-28-2004 16:37:06
What color is the smoke? Oil smoke is blue, excess fuel smoke is black. It could be that the float needle is begining to leak and a bump makes the float sink temporarily running the fuel level high in the carburetor and so running the engine rich.
Gerald J.
gwece
12-28-2004 06:33:41
J.D. Green:
This is a long shot, but check the oil sending unit. Several years ago mine started leaking all of a sudden...wasn't loose, but leaked...have no idea why? Could be hitting bumps makes it worse.
If you do have ring problems or other serious engine problems ask around before you try to rebuild the Onan. Mine developed a serious rod knock a couple of years ago, and the local small engine guys advised me not to try a rebuild because they didn't last long after rebuilding. I finally ended up ordering a new 20 HP Onan from one of the online small engine dealers and have been real happy with it (although it isn't cheap...$1,400 bucks or so). If you end up having to go this route, email me at [email protected] and I'll give you all the info on the engine, adapter, switchover, etc.
gwece
Henry j
12-28-2004 05:31:57
JD
One key to this may be that if the 318 has gradually built up to this or did it just start to happen one day like someone flipped the switch on?
Bradb
12-28-2004 04:33:08
If I had to guess I would say the rings are worn. How many hours are on it? I have a 318 with around 1200 with the same motor. Still runs well.
rinus biemans
12-28-2004 18:33:58
 Re: 318 J D garden tractor smokes in reply to Bradb, 12-28-2004 04:33:08
i lost more oil than expected and finally found the culprit was a gasket that was located where the dipsick goes into the engine .
