'61 4010 Diesel Block
61-4010
12-27-2004 18:58:39
Greetings and Happy Holidays! I"ve got a 1961 4010 diesel and I need a new block. Unfortunately mine is not only cracked but is pitted so bad where the sleeves enter the casting that it will no longer work. :( I can find complete short blocks (e.g. cranks, new sleeves, pistons, etc) from various places but am concerned about that which I can not see. Hence, looking for just a good block that I can rebuild. Any assistance would be greatly appreciated.
Leland
12-30-2004 18:08:26
 Re: '61 4010 Diesel Block in reply to 61-4010, 12-27-2004 18:58:39
Try Johnson diesel service in Shelbyville IL this cat will know where a good one is I belive his # is 217-774 -3812 he is in book if this # is wrong.
61-4010
12-29-2004 11:31:46
FYI....the casting number is R26070. Would appreciate any insight as to where to get a reasonably priced block.
Jim J
12-28-2004 16:27:26
What is the casting number on your old block? And where are you located?
61-4010
12-28-2004 19:33:40
 Re: '61 4010 Diesel Block in reply to Jim J, 12-28-2004 16:27:26
Good evening! The casting number is R26070R. I live just outside of Greensboro, NC. Any help you can provide would be GREATLY appreciated.
Thanks!
Phil/PA
12-28-2004 10:14:04
I get used JD parts from a guy in New York. He advertises in Lancaster Farming. I don"t have the paper in front of me but if I recall correctly his number is 800-730-4020. Don"t know if he has any blocks but its worth a try.
I"m pretty sure that is the correct number but if not let me know and I"ll look it up when I get home.
