KB, �ignition points� are like �slide rules� they are giving way to modern electronic devices so a lot of the younger generation hasn't been exposed to the shortcomings of a points type system. With all the new emission laws the same thing will probably happen with carburetors. 25 years from now someone will wander into an auto exchange center [probably by then all people will do is exchange pre-assembled modules] & ask for a carburetor part & the counter associate [no more parts men by then] will tilt his head, lift his micro on head �heads-up-displays� [no more glasses by then either] & issue the words What!, you want a What? There ain�t no such thing. I do agree with Bob that the points should probably be replaced instead of scratched up with a file but that isn�t always possible, especially for some of us that own a multitude of old iron.. It just isn�t practical to install new points every time we go to move a piece of equipment that has been stored for a year or more.. A couple of strokes with a diamond points file & we�re off to the races.. It doesn�t seem to matter if the points were new or just filed the last time we parked the equipment, after a year in a moist storage area those points will be oxidized & need attention.. I also agree with Bob on the use of a contact cleaner as a follow up to cleaning.. I use a couple of squirts of TV contact cleaner [you-all remember when televisions had rows of brass contacts in the tuner don�t you?].. I haven�t really seen much difference in the life of cleaned points vs. new ones.. Just look at a set of nice new shinny points after they have been in use for a while, they will be pitted looking with a light gray rough looking working area. One good thing that I can say about a points system is: if they quit working, in most cases they can be made operational with a quick stroke of a file, or some scratching with a pocket knife, or even a few strokes with a somewhat flat stone found laying on the ground.. If your modern electronic pick-up module quits due to high temperatures, a mis-connected jumper cable, or moisture entering the assembly you are dead in the water until a new module can be obtained. I just read the other day that due to stricter emission laws that most all motorcycles will be fuel injected by 2007.. Probably lawn mowers & chain saws next. Morning all_____Clooney
