4640 Hydraulic Leak Under Cab??
Mr. Fields
12-27-2004 16:11:51
I noticed that I have a hydraulic leak under my cab on a cyclinder that is under the seat area under the cab. This cylinder is the the small once up high under the cab. There is some kind of valve body that it is attached to, that looks like the leak is coming from. Can anyone tell me what this cyclinder is and what maybe I need to do... Do I have to remove the seat to get to it. There is oil getting in my cab under the seat.
WTW (At Home)
12-27-2004 18:10:39
 Re: 4640 Hydraulic Leak Under Cab?? in reply to Mr. Fields, 12-27-2004 16:11:51
The cylinder is your seat / Hyda/cushion suspension cylinder. The leak is most likely to be at the valve control rod that controls seat height connected to the lever where you make seat height adjustments. If leak is this, rod seal around it can be replaced without removing cylinder. Remove three Phillips screws that hold the plastic cover on, cover located just below the front edge of seat cushion and look to see what is leaking with tractor running while making seat height adjustments, you should see the source of leak. If found to be leaking around the valve control rod, rod can be removed and resealed. Just lift up seat to the top of its normal travel (about 4 inches) and block it up with some wood blocks while working on it. Seat is heavy to lift so have you blocks ready or you may have the next leaking seal! Good Luck, DW
Mr. Fields
12-30-2004 04:31:37
 Re: 4640 Hydraulic Leak Under Cab?? in reply to WTW (At Home), 12-27-2004 18:10:39
Thanks for the advise... That is where my leak is coming from. I have not started to repair it yet, but plan to in a week or so.
