Clooney, thanks for the info. do you have Duane's email address (if he doesn't post an answer in a day or two)? i unhid my email as well. i do have a question. you mention not to force anything. i took the four screws out holding the top stamped metal cover on, and it doesn't come off. should it pop right off, or is it being held on by years of grime, or some other secret component? i guess my concern is one man's "force" is another man's "gently prying". same for the cover over the points. does that cover just pop off, or are there screws somewhere that hold it on? i'm guessing rust is holding it on, but i don't want to force anything apart. also, the mag is currently together, and as far as i know it hasn't been apart since the tractor stopped being used. should the magnets still be somewhat magnetized, or will they go dead after several years? i saw the article in Gas Engine Magazine (i think that's where it was from) on building a magneto magnetizer and was thinking of building one in the spring. a final question (for now), there are cast metal parts on this magneto and the front and rear pieces are cracked. can these be repaired, are repros available, can i cast some out of aluminum? thanks, andy b.
