105 combine engine in 4020
Ray Hud
12-27-2004 10:54:11
What is required to put a diesel 105/404 cu in combine motor in a gas 4020
WTW (At Home)
12-27-2004 18:46:19
 Re: 105 combine engine in 4020 in reply to Ray Hud, 12-27-2004 10:54:11
If you have the tractor and the engine, I wouldn't think twice about doing a swap. The guys that want an old gas 4020 for a collector shouldn't worry or cry there eyes out as they are not hard to find on sales. If they want one they can post on here and I bet I can find one for them. I wouldn't let that be a concern at all. People fail to realize that there may be allot more economical hours left on these repowed gas tractors as many of them never got the hours or wear on them due the there inefficiencies. The gas engine tractors never seem to get the hard work and hours or were used for the heavy work like many of the diesels were. You may have to purchase the correct tractor front pulley as the combine engine pulley will probably not be correct for your hydraulic pump drive coupling. As stated, engine will bolt right in using oil pan and oil pump pickup sump screen from gas engine. I usually just get throttle control linkage from a salvage yard tractor and swap it with what you have now. Flywheel will work but will need to be altered to accept diesel starter ring gear as HTR said. If you have any more questions just post as there have been many guys including myself that have been there and done that / many. Good Luck, DW
HTR
12-27-2004 14:34:57
It's almost a direct bolt in. You will have to have a flywheel, or have the gas flywheel machined so the ring gear from the 105 will fit. You have to use the oil pan from the gas engine, and leave the oil filter on the side of the 105 engine. Building the throttle linkage is some problem, but can be done. If the diesel has a Delco starter, it probably won't crank the engine satisfactorly, with the added load of the hydraulic pump. Get a 12 volt Iskra 4kw direct drive starter. It will spin the engine fast enough to start any time. You have to have a fuel return line to the top of the tank. There may be a few odds and ends, but nothing to give much trouble to hook up.
I have heard that some of the engines are not drilled for the hydraulic pump, but I have seen, changed, and worked on a lot of the engines 404, 466, 7.6, and have never seen any that were not drilled.
I would be interested in buying your flywheel and and flywheel housing , from the combine. You won't need them for the change over. Let me know if you want to sell them.
I think you will have a much more usable tractor, and a lot better fuel econmy.
buickanddeere
12-27-2004 13:36:46
It's can be cheaper and alot less running around to sell the gas 4020 to a collector in the north east. And purchase a diesel 4020. If keeping it for another 20 years. The improved fuel efficiency of a new 6603 will pay for the cost of the tractor.
