12 volt delco alternator
James L
12-27-2004 09:01:58
Any one know how to check test a alternator to know if it's good or bad?
thurlow
12-28-2004 08:46:05
 Re: 12 volt delco alternator in reply to James L, 12-27-2004 09:01:58
Simple matter to build a test stand if you have several of these old alternators. Mine is just an eighteen inch piece of 6 inch channel iron with home-made brackets, fractional HP electric motor (1/2 horse), old fan belt, adjustable/slotted tightening arm, 12 V battery, load tester (mine's from Harbor Freight..... $40, maybe half that on sale) and appropriate wiring w/alligator clips, etc. This won't tell you in detail what the problem is; it will tell you if the alternator is charging. I'm a tinkerer/never throw away anything; by digging through parts of old alternators, can usually fix (probably 3 out of 4 that go bad)them. There are maybe 10 or 12 pieces of equipment that use somewhat similar alternators on the place; might not be worth the effort for only one or two..... ..I've never had much luck fixing, MoPar, Motorola, Ford, etc; Delco's are much simpler (for me).
Hoosier JD
12-27-2004 09:37:17
I would pull if off and go to a local parts house, they generally will test it for free. Good luck, Mike
James L
12-27-2004 10:06:36
 Re: 12 volt delco alternator in reply to Hoosier JD, 12-27-2004 09:37:17
alternator..... ..ty6772 12 volt 72 amp series 10sl,type 106. It's on a 4020, I change from 24 volt to 12 volt with neg- ground, followed instuctions on hook ups everything works except the chargeing system. Is there a way I can check it on the tractor. I have a tester.
Thanks Jim
Clooney
12-27-2004 14:38:24
 Re: 12 volt delco alternator in reply to James L, 12-27-2004 10:06:36
James, I don't list a ty 6772 in my Delco alternator listings so we will just have to wing it..
To check while on the tractor, first use a test light [or voltmeter] & verify you have full battery voltage at the big output stud on the back of the alternator.. If yes, go to next test,, if no you have an open in the wire from the battery to the back of the alternator.. You need power there all the time even with the ignition switch turned off..
-Next find the #2 terminal on the side of the alternator case [it�s one of the two at that side plug].. That also must have battery voltage at all times [if not post back here & we�ll help you wire that correctly].. The wires must remain plugged in to test the above as the power comes from the wire.
--Next, unplug that connector & test for partial battery power at the #1 terminal.. Depending on the resistance of your test light or the impedance of your volt meter you will show anywhere form 5 volts to full battery voltage.. The ignition switch must be turned on for this test.. Usually a test light will glow when connected but maybe not full brightness..
The above will show if the alternator is at least wired correctly to charge..
If that side terminal area just has a plastic cover on it with no wires post back & let me know then don�t do the above tests. [we�ll go another direction if those terminals are covered].
If the above tests are ok & it still doesn�t charge there is a way to probe the regulator through the alternator case & force a charge but that test hole looks like other holes so we�ll hold off on that for now as you can damage the alternator if probed in the wrong hole.
After the above, about all you can do is pull the alternator & take it apart to test the internal components or take it to a shop to be tested on a machine..
Do the above tests & post back with the info..
Clooney
James L
12-27-2004 17:15:00
 Re: 12 volt delco alternator in reply to Clooney , 12-27-2004 14:38:24
I tested at the Bat. termimal it shows 12 volts there, Ignition switch wire also has 12 volts, with ignition switch on voltage sense terminal also has 12 volts. When I run the engine even at 1500-1700 R.P.Ms. alta light will not go out. I thank you for your help..... ....Jim
James L
12-27-2004 17:13:02
Clooney
12-27-2004 17:32:40
 Re: 12 volt delco alternator in reply to James L, 12-27-2004 17:13:02
James, good,, now we know everything is good there. Next turn the ignition switch on & pull that connector from the alternator [the one with the #1 & #2 wire in it].. If the light goes out you have an internal alternator problem.. If the light stays on your problem is in the light circuit itself..
~If the light stays on even with the plug disconnected plug it back in & start the tractor,, once warm run it at fast idle & use your voltmeter across the battery posts.. If the voltage reads above 13.8 or so [14.2 desired] your alternator is working ok & the light circuit will have to be looked at..
~If the voltage is low,, around 12 or so your alternator is defective & will have to be removed & tested..
~If you find the alternator is bad, pull it off & post back & I will talk you through a basic diode, diode trio, stator & rotor test.. If the problem is anything more than a broken brush or failed regulator it will probably be cheaper to buy a rebuilt than install new internal parts..
Let me know what you find..
Clooney
James L
12-27-2004 18:03:12
 Re: 12 volt delco alternator in reply to Clooney , 12-27-2004 17:32:40
Clooney, when I pull the plug on #1&2 the light goes out, when I had the engine running I put the voltmeter on the Battery posts it showed no increase in voltage. Must be my alternator haveing a problem!!! I will pull it and have it tested. Let you know how I made out in a day or two.
Thank you much....Jim
James L
12-29-2004 17:55:48
 Re: 12 volt delco alternator in reply to James L , 12-27-2004 18:03:12
My alternator checked out OK, I must have it hooked wrong. How are these old girls wired? I have a starter with a piggyback relay, alternator with 3 wire hook up. how is this all wired with ignition switch? 12 volts.
jim.
Clooney
12-30-2004 07:20:16
 Re: 12 volt delco alternator in reply to James L, 12-29-2004 17:55:48
James, if you had the power at the points I had you test to begin with it was wired correctly..
But here it is for you,,
*The large stud on the back of the alternator goes to the positive battery post, either directly or through an ammeter.
The #1 alternator terminal hooks to switched ignition power that is powered up when the ign switch is on with a 10 ohm resistor in the wire [note: it will still work without the resistor but will eventually damage the alternator]
The #2 alternator terminal hooks to the large stud on the rear of the alternator & is powered up all the time..
For that alternator to charge you must have a negative ground 12 volt system..
Clooney
Clooney
12-27-2004 09:17:49
James, sure we can help you out.. BUT, we need to know what Delco alternator you are working with?
Either give us the alternator model or any numbers on it, or tell us what it came out of & the year [just get close on the year].
We also need to know if you have an ohmmeter & know how to use it?
On most Delco�s you will hear a distinct whine when they are at full output so you can use that as a quick test.. On the earlier ones you can place a screwdriver or pliers on the rear case at the bearing area & you will feel a magnetism if they are charging.
Some of the later Delco�s aren�t easily survivable but with a soldering iron & some ingenuity they will come apart,, problem is, finding parts..
Let us know what you have? And let us know what you are using it on?
Clooney
