DEERE MODEL B #278094 WIRING
STEVE and TAYLO
12-27-2004 08:45:57
Recently restored this machine.Have had alot of trouble putting the wiring back, as simple as it is. I have a 12 volt battery. No Key. although it used to have one, the wiring schematics I have found do not show a key?
Installed a new ammeter gauge that never seems to show it is charging. Yesterday I went to fire it up and the battery is dead. While hooking up the charger I noticed that I have it grounded off the negative post. Isn"t it supposed to be positive ground? Would this make a difference in charging? If I switch the posts around will I damage anything, or will I need to change all the wiring?
It starts good like it is, but the battery dies after awhile, especially if I use the lights. Also I would appreciate knowing if it is supposed to be key switched, right now I just choke to death to stop it. It is a late 1951 production. Thanks
ChuckW
12-27-2004 14:45:41
 Re: DEERE MODEL B #278094 WIRING in reply to STEVE and TAYLOR, 12-27-2004 08:45:57
Clooney and John T. have covered the electrial but wanted to comment on chocking to stop tractor. If you choke is working correctly you shouldn't be able to do this as it should have a spring pull off. Also those tractors were designed to be stopped with the gas lever and it will completely shut down. The butterfly closes down completely unless someone has bent the stop over to prevent this. A lot did as they didn't want to take time to adjust lever on power down. The only problem is you have eliminated the Safety factor that John Deere installed. This was a fail proof way of shutting down if you were in trouble. You may not have the 2-3 extra seconds to lean over to flip or pull a kill switch. I would recommend you reset this, install a ground push pull on the dash that will ground you magneto. Some of the mags had these included but you can get parts and add one.
Mike M
12-27-2004 10:23:47
Let me add one more thing. Don't choke it to stop it. That will wash down your cyilnder walls and may even dilute your oil with all that raw gas in there,not to mention foul your plugs it's a wonder it still starts up. You should be able to adjust the throttle lever to shut it off when pulled back that's how they were on that year.Or better yet,but slower, turn off the gas at the fuel bowl shut off and let it run out of gas.
John T
12-27-2004 10:20:55
Steve and Taylor, I can probably help you out, but first I have to ask some questions to figure out how its been configured and what ignition you now have (Magneto or original Wico XB Distributor with internal coil or a Delco Distributor with external coil) as it could have been converted over the years away from the original????? ??? Regardless, if it has/had a key operated or an ON/OFF Ignition Switch and its now equipped with a battery powered coil igniton instead of a Magneto, you have to shut the power off with a switch or key switch so you dont discharge the battery and heat up the coil when shes not in use!!!!! !!!!! !!!!
CAUTION:::::IF IT HAS A COIL IGNITION (NOT a Magneto) and you kill it by choking but the points n coil continue to draw current, you discharge the battery plus heat up the coil and points. SHES GOTTA HAVE A SWITCH OR A KEY SWITCH IF ITS A NON MAGNETO COIL IGNITION
QUESTIONS FOR YOU, does it have a battery powered distributor and coil ignition like a Wico XB (original) Distributor or a Delco Distributor, or is it a Magneto Ignition???? If its a Wico XB Distributor (as on an original 6 volt B system, they look a lot like the Wico X Magneto) and youre running it at 12 volts, you need an extra external voltage dropping ballast resistor or you can harm the internal Wico Coil. NOTE even if it originally had just an ON/OFF switch OR a Key operated switch, you still need some sort of switch to shut the power off if its a battery powered Coil Ignition, Wico XB or Delco or else the battery will discharge and the coil and points heat up when not in use!!!!! !!!!! !!!!!
BOTTOM LINE, I need to know what Ignition you have, if its a Battery powered coil/distributor like an original Wico XB with internal coil or a Delco Distributor or a Magneto ????? ????? If its a Wico XB, if you have the extra external ballast to reduce the 12 battery volts down to 6????? ????? ?? If its a Delco Distributor and external coil, what is the coil voltage and if 6, does it have the external Ballast which drops coil voltage down to 6 ????? ??? ORRRRR is it a Magneto which requires no external battery power????
NOTE: Some Magneto Ignitions such as the Wico X (which looks similar to the Wico XB Distributor) had a kill switch terminal which was wired up to a dash switch used to kill the spark when switched to OFF. Dont confuse that with an input power terminal like on the Wico XB Distributor.
BASIC WIRING: If it has a battery powered coil ignition, regardless if Wico XB or Delco:
The ammeters supply side terminal receives power from the ungrounded battery post often via the starter lug,,,,, ,,,,the ammeters other load side terminal feeds the BAT terminal on the Voltage Regulator,,,,, ,,,,,loads like lights and ignition (it has an ignition switch to then feed the coil ignition per the above) receive power EITHER from the LOAD terminal on the VR if its a 4 wire VR or the ammeters load side terminal if its only a 3 wire VR. The ignition switches BAT input power is from either the VR"s LOAD terminal or the ammeters load terminal and then must turn the igntion ON or OFF to feed the coil/distributor
NOW TO SOME OF YOUR QUESTIONS
YESSSSS SSS It was originally POSITIVE GROUND.
If you change over to NEG ground, YESSSSS SS it affects the charging system, but it could still work and charge if you properly polarize it,,,,, ,reverse the ammeter leads so it dont read backwards,,,,, ,and maybe reverse coil polarity, depending on what ignition you have. HERES WHAT I SUGGEST UNTIL I HEAR BACK FROM YOU TO POSSIBLY CURE THE CHARGING PROBLEM. First, hook the battery up as POSITIVE ground,,,,, ,,,Polarize the Generator,,,,, ,,have the ammeter wired so the supply side terminal has only one wire and that leads to the hot ungrounded - battery post, (possibly via the starter lug terminal) with its other load terminal feeding the BAT terminal on the VR. The VR"s LOAD terminal feeds the Ignition switch and light switch if its a 4 wire VR (BAT ARM FLD LOAD) with the 4th LOAD terminal or else the ammeters load terminal feeds those same circuits if its only a 3 wire VR (BAT ARM FLD).
My best guess is it originally had a switch (push/pull) and was a battery powered 6 volt coil ignition (probably a Wico XB but maybe a Delco conversion). HOWEVER, if its been converted over to 12 volts and shes NOT a Magneto Ignition, you need an external voltage dropping ballast resistor (regardless if Wico XB or Delco) and a switch of some sort (regardless if key operated or push/pull) OE ELSE THE BATTERY WILL DISCHARGE AND THE COIL HEAT UP if its kileld by choking and the powers not turned off.
Post back yur findings, answers to my questions and any other questions you may have and feel free to e mail me at [email protected] or call me with any other questions. Once I know what ignition you have and if its ballast resistor equipped etc I can e mail you how to wire it up.
Let me know, Good luck n God Bless n Merry Christmas
John T Nordhoff in Indiana
Clooney
12-27-2004 09:45:47
STEVE and TAYLOR, yes we can help you out.. ~The 12 volt battery didn't come with that tractor [it was 6 volts from the factory].. If you still have the original 6 volt generator & regulator it will never charge that 12 volt battery..
~On the battery being negative ground?.. It came originally as positive ground.. I hesitate to have you swap it to positive ground until we find out what you have for a generator or alternator.. If the tractor now has an alternator on it, it will have to remain negative ground or it won't work & could cause system damage.
~That late "B" probably came with a distributor so that could explain the key switch.. Some key switches were also hooked to a mag shorting post to allow the mag to be shorted to stop the engine & lock out the ignition.. Most were used with the distributor option though..
�.OK, now on to your problem�.
Here�s what we need to know to help you..
1)- We need to know IF your tractor has a generator, if so what numbers or marking are on it? We also need any voltage numbers or markings that are on the regulator.. (see #2)
2)-We need to know if it has an automotive alternator on it.. If so what type or markings on it.. If you can�t tell what you have, E-Mail me a picture [or post it here].. If you can�t take a picture have an auto or tractor savvy person look at it for you [they will be able to tell quickly]
3)-We need to know if you have a magneto or a distributor on that �B�.. Caution: the Wico XB distributor looks just like a Wico X magneto.. If you can�t tell, again E-Mail me a picture.. Will the tractor run without any wires hooked to the mag/distributor? You say you have to stall it to shut it down so that probably means a mag but you never know. Can you hear a distinct klack as you spin the engine over? If so you have a magneto.
4)-How adept are you at wiring & following wire prints? I have a multitude of different wire prints drawn up for the late �B� showing everything from a mag on an alternator equipped tractor to a 12 volt generator using a distributor. To one wire alternators, to unique alternators.. I can probably supply you a good to work from wire print but REALLY NEED TO KNOW what you are working with there..
Once we figure out what you have as far as charging system, ignition system, & intended usage we can get your problem figured out for you.. Remember a lot of those tractors have been modified over the years [your 12 volt battery shows that]..
Clooney
STEVE AND TAYLOR
12-27-2004 10:24:56
 Re: DEERE MODEL B #278094 WIRING in reply to Clooney , 12-27-2004 09:45:47
Clooney,
I have a Wico X magneto #VC189610. I have what I believe to be a distributor - Delco Remy with model #1101390 Ser. #0018. On top of the distributor is a voltage regualtor with 3 posts. The regulator is about 3" square and black in color.The guy I bought it from had a key switch on it, and yes I think it did short to a post, but I don't remember how he did it. He also made a comment about maybe needing a different regulator to work properly. I have since talked to him about it, but he really doesn't offer much information. Also now, my lights quit working. Maybe it had 6 volt lamps and I burned them out by putting 12 volts through them? I really appreciate your help and yes I'm O.K. with reading wiring diagrams.
Steve
John T
12-27-2004 11:10:39
 Re: DEERE MODEL B #278094 WIRING in reply to STEVE AND TAYLOR, 12-27-2004 10:24:56
Steve and Taylor, Sorry I missed this updated post info above, I been runnin in n out and on phone and trying to answer in between all at the same time lol, I sincerely apologize but hopefully, we will eventually get you all fixed up.
You mentioned a Wixo X Magneto PLUS you mentioned a Delco Distributor, which do you have?? Many Wico X mags had a kill switch terminal out the side which was wired to the dash to ground out n kill the spark!! Such a kill switch may appear as an Ignition switch or even a key operated siwtch!!!
The Delco distributor isnt really a 6 or 12 volt thing so much, the 6 or 12 volts is how much is applied to the coils high input (from switch NOT to distributor) terminal, while the Delco just uses its ignition points to conduct (points closed) or interrupt (points open on hign cam) coil current via its other low side (to distributor) terminal.
If it has a "Voltage Regulator" (NOT talking aBOUT ANY CHARGE SYSTEM vr HERE), my best guess its job was to reduce the incoming 12 battery volts down to 6 to feed the coil, same as what an external Ballast Resistor usually does. It would have received full battery voltage via an ON Ignition switch or Key witch,,,,, ,,,,dropped it down to 6 volts,,,,, ,,,then fed the coils high input terminal while its other output terminal was wired to the Delco distributor which supplied the ground return path via closed igntion points.
This assumes by Voltage Regulator you mean an aftermarket voltage regulating device of some sort device AND NOT the Charging System Voltage Regulator which also has 3 or 4 terminals labeled BAT ARM FLD LOAD etc????? ? To charge a 12 volt battery, you need a 12 (NOT a 6) volt VR!!!!
YES, its possible to burn up 6 volt lights by applying 12 volts to them. Was the Voltage Regulators output wired to light circuits in addition to the coils input????? ? What are the Voltage on the Voltage Regulators terminals???
Again once we know for sure what Ignition and some sort of "Voltage Regulator" or ballast you have and if you have a 6 or 12 volt Gen and VR we can get you going.
Let us know, sorry more questions than the answers youre looking for now and sorry for not being able to keep up here and on phone grrrrr rr
John T
STEVE AND TAYLOR
12-27-2004 17:47:59
 Re: DEERE MODEL B #278094 WIRING in reply to John T, 12-27-2004 11:10:39
John-
I replied to you but didn't see it posted. I know that I have a mag. The guy before me was a cobber and had a key switch wired into the mag through a notch he had cut in the cover. I have a generator with a 3 post VR mounted on it. It looks original, 6 volt I suspect. I think at this point I would like to get a 6 volt battery, positive ground and go back to what ever was original. I have no coils, and the key never started the beast. As far as the lights go, they had been working fine since last winter, all of a sudden they all died.
Anyway I would appreciate any further help, I'm sure it is simple, but I have nothing I know for sure to start from.
Steve
John T
12-27-2004 19:44:14
 Re: DEERE MODEL B #278094 WIRING in reply to STEVE AND TAYLOR, 12-27-2004 17:47:59
Thanks Steve, see my post below for answers to your latest questions and thanks for the feedback and updated info. Let us know how she turns out n glad we were of help.
God Bless n Happy New Year
John T
STEVE AND TAYLOR
12-27-2004 17:37:46
John-
Yes I have a generator. The 3 post VR is mounted on top of it and looks very original. I think what I need to do is go back to the 6 volt battery and related sytem. The guy who had it before had a key switch that killed the spark. He had cut notch in the mag cover and ran a wire to something. I just can't seem to retrace what he did. I have no coils and the key never started the engine. I know that I have a magnito system. The guy who owned her before had a Phd. in cobbing. I've made everything else original, except the wiring - I don't even know what was original. I wasn't even born when this beast was concieved!
By the way- where are you that you have snow. I'm in upstate NY and should be waist deep in it, instead my yard needs mowing!
Steve
John T
12-27-2004 19:42:33
 Re: DEERE MODEL B #278094 WIRING in reply to STEVE AND TAYLOR, 12-27-2004 17:37:46
Hey Steve, Im in Bloomington Indiana but I will be up your way since John Jensen has asked me to return to the New York State Expo next July to give Seminars as I did at the last 2003 Expo. I will be giving Seminars on Charging Systems and Coil Ignition Systems, so stop by and introduce yourself. See my posts below for answers to your latest questions, this is a longgggg gggg thread, but were all glad to assist you.
John T
Clooney
12-27-2004 10:57:24
Steve, you say ..
Quote: -- �I have what I believe to be a distributor - Delco Remy with model #1101390 Ser. #0018. On top of the distributor is a voltage regualtor with 3 posts�
--I take it that you meant to say GENERATOR? Well actually I�m certain of that. The bad news is that Delco 1101390 is a 6 volt generator, luckily it is a fairly decent @ 15+ amps @ 2000 RPM.. That is the reason you can�t get a charge into that 12 volt battery. It probably still has the original 6 volt regulator on it also.
~OK, we have a few ways to go here//
~Before we proceed let me know if you want to make the full conversion to 12 volts or make it original & swap back to the full 6 volt system..
~Here�s the low-down.. IF, you keep that 6 volt generator you can install a 12 volt regulator & get it to charge but it will have a hard time keeping that 12 volt battery charged in cold weather or with the lights on.. A 6 volt generator CAN charge at 12 [well actually 14] volts but the generator speed [that also means engine speed] will have to kept fairly high.. I have done it in the past but it�s not a very forgiving system..
~Your options are
--Convert back to 6 volts [will need a new battery]
--Buy a 12 volt voltage regulator & get as much as you can from that 1101390 [will cost a bit for a new regulator]
--Keep the 12 volts & install a GM alternator [fairly cheap & will give plenty of charge]
--Buy & install a 12 volt generator & regulator & build it to look original [costly but looks the best]
~Let me know what you want to do & if you plan to keep that 1101390 6 volter & 12 volt battery we should probably wire it up correctly & test it before spending the money to buy a regulator.. You should probably look for a smaller generator pulley also if you want to charge 12 volts with that 6 volt generator
~As for the lights? Those probably didn�t make more than about a minute at 12 volts so you will probably need new there also..
~Anything you need wiring diagram wise to meet the above I have that already drawn up so let me know..
Clooney
STEVE AND TAYLOR
12-27-2004 17:25:55
 Re: DEERE MODEL B #278094 WIRING in reply to Clooney , 12-27-2004 10:57:24
Clooney,
You are such great help! Thank you.
Yes, I have a generator. Yes I would like to go back to the original 6 volt system - because it is original.
I have every reason to believe the distributor and voltage regulator are original 6 volt. Easiest way out is to buy a 6 volt battery. Can you help with the wiring diagram? What about that key switch? As John T talks, I have no coil. The switch simply killed the spark, it used to have a wire going to the magnito and onto a screw. problem is i don't know what screw. Was the tractor originally equiped with a key switch, or did the guy before me cob this together? He had a small notch cut into magnito cover to get a wire in there - that does not seem original. I appreciate all your help. Please let me try one of your wiring diagrams.Should I go back to the positive ground?
Steve
Clooney(slow loading pic)
12-28-2004 05:13:35
 Re: DEERE MODEL B #278094 WIRING in reply to STEVE AND TAYLOR, 12-27-2004 17:25:55
third party image
Steve, was looking at my photo archives for a picture as a follow up to a recent E-Mail & found this (Wico Mag) grounding stud picture.. Thought you might like a look at it.. It shows 2 different Wico mags with the possible places for that insulated grounding stud.. If your mag has a stud like in either picture just run a wire from it to one terminal on that dash key switch, then run the other terminal of that dash key switch to a good ground.. That way the key switch can be used to ground the mag & stop the engine..
Clooney
John T
12-27-2004 19:38:05
Steve, thanks for the update, and now knowing you have a Mag Ignition and a Delco Generator (NOT a distributor as you said above) it sounds like were gonna get you there, so hang in there and lets take this one step at a time.
1) First the key switch situation: Since you have a Wico X Mag, its possible to kill the spark by running a No. 16 or so wire from the Wicos lil side terminal stud, to and through a dash switch (key operated or push/pull or toggle) then to frame ground when you wanna kill the spark. I suspect it may have originally used a key or a push/pull toggle switch originally and a Wico XB distributor, but its still possible to kill that Mag with either so long as its at least a SPST switch which is normally OPEN for RUN and Closed for the ground connection to ground out the mag n kill the spark for STOP.
Many Wico X mags have the lil side out insulated stud/terminal (wires inside to the points) where the kill wire attaches but it sounds like the one you have is jury rigged with a wire out the side??? If your mag case has the hole and you wanna install a kill switch (key or push or toggle) it may be possible to buy the insulated stud assembly and make her look more original. Check with Duane Larson or Robert Beaver for those parts.
NOTE I still prefer to kill them by shutting the gas off and letting them die but a mag kill switch can still be a good safety feature.
NOW LETS GET HER CHARGING:
YES I agree if you wanna take her back to original, all you gotta do is get a 6 volt battery, and I HIGHLY recommend the biggest heaviest rated unit that will fit into the battery compartment. ALSO use 00 Gauge Battery n Starter n Ground Cables for best performance.
YES, she was originally POSITIVE ground and I recomend you go back that way.
NOWWWWW WWW, once that heavy duty 6 volt battery is installed at POSITIVE ground, lets check the wiring and get you charging, heres how to wire the Voltage Regulator:
BAT terminal on the VR up to the ammeters load (NOT to battery) terminal. The other supply side of ammeter gets connected to the hot ungrounded - battery post, often via the starter lug. That ammeter load terminal aLSO FEEDS THE LIGHT SWITCH.
FLD on VR to Gens Field (smaller of the 2) posts.
ARM (or GEN) on VR to gens Armature (larger) posts.
POLARIZE by first temporarily dead grounding the Gens Field post to its frame,,,,,then momentarily flASH JUMP a wire from the VR's BAT terminal over to its ARM terminal and you ought to get a spark, then remove the jumpers.
NOWWWWW WWW is she dont charge, here is a Troubleshootign procedure to see if its a gen or a VR problem:::::::::::::;
1) With tractor running, temporarily dead ground the Gens Field post to frame ground and see if she chareges then????? ?? If so but not otherwise, the VR is bad or the VR isnt well grounded to the Gen or the wires open between VR's FLD and Gens Field post.
2) If she still dont charge, leave Field grounded but then jump a wire from the VR's BAT terminal over to its ARM terminal. If she charges then, the VR is bad or a wires misisng from the Gens ARM post to the VR's ARM terminaL.
3) If she dotn charge with the Field grounded and BAT and ARM on the VR jumped together, its likely that the Gen is bad, assumign the belt is good n tight,,,,, ,,,Gen and VR are both well grounded,,,,, ,,,and the ammeters is good n wired correct.
Common Gen problems are worn down brushes or the brush hold down spring assemblies are stuck and not holdign the brushes tight down against the commutator. Other problemns may be a shorted armature.
Sooooo oooo glad to be of help, thanks again for the updates n feedback, n it sounds like if you get her genning you will be good to go. Once wired correct post back your results and any more questions or call me at 812 824-4608 or e mail me at [email protected] wiht any more updates n questions.
God Bless Merry Christmas n Happy New Year, let us know what happens now ..... .....
Clooney
12-27-2004 17:56:36
Steve, lets start with the key switch.. It was probably used originally with a Wico distributor.. I can't tell you if it is original or not [could have been].. I had a "B" that came with a key switch & magneto & the original owner swears it came that way.. Probably was shipped to the dealer with a distributor & the dealer traded it out for a mag.. In fact I have an old beater B right now that has a key switch & a mag.. It just sits there & does nothing� I�m not sure you can use the key switch as a shorting switch as I don�t think the key will come out with it in the stopped position.. Well let me re-phrase that, you could use it but would have to turn it back on to remove the key.. That�s a simple wire up.. just hook one post of the key switch to a good clean dash ground & hook the other post to the condenser attaching stud on the points [either through a wire run into the mag or by adding an insulated post through the side of the mag housing].. If your present mag has an insulated stud on the front or back [sticking through the metal housing] just hook to that.
~I will send you a wire diagram once we figure out if your generator is good.
~Now lets test the generator�..
>>To test the generator... first, remove the fan belt & both wires going to the generator posts,, then, run a jumper wire from the NON-GROUNDED battery post to the generator's [A] post,, that should start the generator motoring,, then, short the generator's [F] post to the generator's case,, the generator should then slow down.. [If the generator doesn't motor you have a bad or stuck brush, bad armature, oxidized commutator, or broken internal wire.. If it motors but doesn't slow down you have an open field brush or open field winding, or broken internal wire..
>>If the generator isn't working you can remove the rear end frame [cover] & clean the commutator, clean & free up any stuck brushes, or look for open internal wires.. More than that will take an ohmmeter & further testing procedures.. Any problems here just post back or E-mail me..
~Once the generator is deemed operational we�ll wire it up using the regulator that�s on it now & see if that works [maybe we�ll get lucky].. You will need a 6 volt battery or at least borrow one for the generator/regulator test..
So, test that generator & if it�s good post back or E-mail & I will send you a wire diagram.. Then you can wire it up & we�ll give it a whirl..
Clooney
John T
12-27-2004 11:35:58
Bill, Great to have you back (especially with your Delco spec n data base of valuable information) and I hope you had an enjoyable trip. Ive had decent luck getting a 6 volt Generator to charge a 12 volt battery simply by swapping out to a 12 volt VR. We know its not perfect or correct, but that it can work lol. I was wondering what luck you had in doing the same?????
Again, welcome back n May God Bless ya for the help you provide in this great hobby we love n share.
Your friend to the South, John T in Indiana
PS wheres the e mail like last years snow fall picture in your area????? I think I e mailed you lately and included a pic unless I forgot
Clooney
12-27-2004 12:24:15
 Re: DEERE MODEL B #278094 WIRING in reply to John T, 12-27-2004 11:35:58
John, I've had mixed results using a 6 volt generator on a 12 volt system.. First off, as you know the amperage goes down as the voltage goes up so the amperage possible is about 1/2 what it was.. The problem is the generator speed must be kept up so far that the engine can�t be idled for long with the lights on, & the fact that most 6 volt generators are quite low on output to begin with so there just isn�t much there.. It�s that higher generator speed needed that gets you�
I have had fairly good luck with the old Ford 9 N as that engine runs faster anyhow & by grinding on the 3rd brush holder a little that allows a fair output.. Still won�t run all night with the lights on without a real good battery though.
On the Deere�s, I have had acceptable results if the tractor isn�t used with the lights on & the tractor has a magneto as all it has to do is keep the battery up.. That seems to work pretty good. Doesn�t seem to do the trick for winter use when plowing snow with the lights on & keeping the RPM�s down to limit wheel slippage.. It really depends on the number of starts verses the high RPM charge time & how much the lights are used.
On my winter snow plowing 720D I do just the opposite.. I use a 20 amp 12 volt generator with a 6 volt regulator.. That allows the factory lights + extra lights & keeps the little 6 volt battery up even at idle conditions. I suspect I will eventually burn the regulator up but it has been ticking along for about 10 years now.. The 12 volt generator has smaller wiring in it but that hasn�t caused a problem either [time will tell]..
You want Snow I have snow for you.. I do have a camera full of snow pictures just haven�t downloaded them yet.. Sounds like you got enough of your own snow this year though..
Regards_____ Clooney
John T
12-27-2004 14:18:25
 Re: DEERE MODEL B #278094 WIRING in reply to Clooney , 12-27-2004 12:24:15
Nope, we dont need any more snow lol, I just enjoyed the e mail pic you sent me last year when it looked pretty up at your place. Sounds like our 6/12 Gen experiences are similar, they do work but nuttin to brag about and I fear we may overcurrent the Field windings but Ive still never had any go bad.
Based on your Delco specs (one reason Im glad youre back to offer your specs n data plus a valuable second opinion) it sure sounds like he has a Wico X Mag and a Delco GENERATOR NOT DISTRIBUTOR as he said he had, in which case all we gotta do is have him kill it by running it out of gas or installing a kill switch then simply fix his charging problem.
Fun thread, take care my friend.
John T
J. Schwiebert
12-28-2004 18:27:39
 Re: DEERE MODEL B #278094 WIRING in reply to John T, 12-27-2004 14:18:25
Hey John T. How can I contact you?
John T
12-28-2004 19:26:25
 Re: DEERE MODEL B #278094 WIRING in reply to J. Schwiebert, 12-28-2004 18:27:39
You can e mail me at [email protected] or call me at 812 824-4608
