37A motor oil
leo
02-12-2004 03:09:31
guys , I asked this before but I forgot the answer.
should I use 10w30 in my tractor? or was that 30 weight ?
I appologize for asking twice.
leo
old
02-12-2004 08:39:19
 Re: 37A motor oil in reply to leo, 02-12-2004 03:09:31
This comes out of an oringinal owners manaul for a 1935 JD-B -SAE 50 for above 95 degrees, SAE 40 for 65-95 degrees SAE30 for 30 -65 degrees. Muti weight oil can give oil preassure problems also, I put 10W-50 in my B and didn't have the preasure it should have had but with the 30 in it the preasure is just as it should be
Clooney
02-12-2004 03:48:28
Leo, those older tractors like the 37A like a straight weight motor oil.. If only used in warm weather use a 40 weight oil. If used in cooler weather use a 30 weight oil..
~For just playing around you can use a multi-weight like 10W30 but it is real prone to leaking & is pretty thin for that old engine...
~For winter use the 10W30 will also work good..
[email protected]
