G PISTONS + RINGS
Doug K.
12-27-2004 06:50:11
Bored block .045 Bought new rings from Hastings. Measured old rings .247 measured new rings .235 How can that be? Old ones have more meat than new ones. Also cast pistons have rist pin wear. Can local machine shop fix. THANKS DOUG
Clooney
12-27-2004 08:25:14
 Re: G PISTONS + RINGS in reply to Doug K., 12-27-2004 06:50:11
Doug, you have the wrong rings..
The old rings are 1/4" & The new rings appear to be 15/64".. Call Hastings,, possibly those new rings are meant to be used with ring backers [ring spacers].. In any case MAKE SURE the ring to piston side gap is under .006" & probably closer to .003" would be much better.
Clooney
