Does anyone have a john deere 720 steering wheel?
blakeinabilenetx
12-26-2004 18:01:55
Need one.
thanks
JerryBird
12-27-2004 05:35:14
 Re: Does anyone have a john deere 720 steering whe in reply to blakeinabilenetx, 12-26-2004 18:01:55
Give Triple G Service a call .Last I checked they had correct reproduction steering wheels for all 2 cylinders.Their toll free number is 1-888-720-0830.
Clooney
12-26-2004 18:18:52
blakeinabilenetx, are you looking for the early 3 spoke, or the early 4 spoke, or the late all plastic wheel? There are some differences depending on your serial number & if it has power steering..
Clooney
blakeinabilenetx
12-26-2004 18:21:42
 Re: Does anyone have a john deere 720 steering whe in reply to Clooney , 12-26-2004 18:18:52
clooney, I believe it is a 3 spoke
Clooney
12-26-2004 18:30:53
 Re: Does anyone have a john deere 720 steering whe in reply to blakeinabilenetx, 12-26-2004 18:21:42
blakeinabilenetx, is that a 3 spoke steel or plastic? I believe the steel 3 spoke is the rather common AA 380R..
Clooney
blakeinabilenetx
12-26-2004 18:49:20
 Re: Does anyone have a john deere 720 steering whe in reply to Clooney , 12-26-2004 18:30:53
I don't know if you mean solid steel or solid plastic? But, plastic broke off of the center piece.
Clooney
12-26-2004 18:59:50
 Re: Does anyone have a john deere 720 steering whe in reply to blakeinabilenetx, 12-26-2004 18:49:20
blakeinabilenetx, it sounds like you have [had] the late plastic wheel.. I doubt very much you will find a good used as those things crumble due to age, vibration, & ozone exposure.
~You have a few choices on the plastic wheel,, you can buy a cheap repo wheel that will work ok but not look original from up close/ or spend a fair amount of money & get a good repo from a reputable dealer & have a wheel that will look original.. Just the plastic center alone isn�t cheap on those plastic wheels..
Clooney
blakeinabilenetx
12-26-2004 19:03:16
 Re: Does anyone have a john deere 720 steering whe in reply to Clooney , 12-26-2004 18:59:50
Cheaper is better...??
Clooney
12-26-2004 19:23:02
 Re: Does anyone have a john deere 720 steering whe in reply to blakeinabilenetx, 12-26-2004 19:03:16
blakeinabilenetx, well I can't recommend any places for the cheap ones as I only buy the good ones but a quick check on EBay shows a wheel for your tractor with a current bid of about $31.00..
Look in green Magazine & you will find plenty of wheels advertised..
Clooney
blakeinabilenetx
12-26-2004 19:27:20
 Re: Does anyone have a john deere 720 steering whe in reply to Clooney , 12-26-2004 19:23:02
Hey, no fair I already checked there and did not find anything. Thanks, though.
