HELP Unstyled A rings
howard1938
12-26-2004 17:26:50
I have a 1938 John Deere A, that is bored to .045 over size both the rings and the pistons are .045 over but I bought new rings from the dealership and the ring end gap is still to much; about .062 my manual calls for a gap of .040-.050. The real question Iam asking, could I have the wrong rings, I thought I ordered the .045 oversize; can I order .090 rings and file the ends down or do I have bore the block and replace the ring and pistons with .090 oversize; would rather not bore the block but I will do what ever is necessary to get it back to the proper specifications.
Clooney
12-26-2004 17:46:25
 Re: HELP Unstyled A rings in reply to howard1938, 12-26-2004 17:26:50
howard1938, where in the cylinder bore are you checking the ring end gap? It MUST be checked at the tightest place in the cylinder bore [that�s usually near the bottom of the bore].
~If those rings are still too small even if measured at the tightest place in the bore you have a couple of options.. The first is to just use them.. Ring end gap is not nearly as important as the ring side gap as far as allowing combustion blow-by to occur.. Personally I would rather have a slightly large ring end gap than a gap that is too small.
~Using the next oversized rings will mean a lot of filing to get then down to size & could leave them a little tight in the bore so that probably isn�t the best option�
~Make sure you have ordered the correct size rings [you probably have as the end gap changes significantly with minor bore diameter changes].
~You could always call Otto Gas Engine Works & have custom rings sent out. [see link below]..
Clooney
