Bendex
Hayfarmer
12-26-2004 16:12:16
Hi put a new Bendex on my 430 a wile ago, the old one was worn on gear. New one is cut a little differnt in splines. It sometimes hangs up on starter end, so starter just spins and bendex does not throw in. Battery on tractor seems ok and am running 12 volts so starter spins fine. Wondering if anyone has run into this before. I took some emery cloth and leaned up splines on the back, cleaned off grease on splines and lubbed with graphite. Is there any way to get the outer end off the bendex? I remember some older ones had a snap ring but this does not seem to have one. Any help would be appreciated.
Clooney
12-26-2004 17:05:08
 Re: Bendex in reply to Hayfarmer, 12-26-2004 16:12:16
Hayfarmer, it sounds like you either have a defective new starter drive [bendix] or have an incorrect drive for your starter..
~That starter drive must slide on the starter armature easily & without any hang-ups. Is the drive head & drive spring installed correctly?
~As far as taking it apart? I can�t comment on that without looking at the drive unit. Some of the replacements are staked together so aren�t serviceable.
Clooney
Hayfarmer
12-27-2004 07:24:36
 Re: Bendex in reply to Clooney , 12-26-2004 17:05:08
Thanks for the response. Bendix seems to be like old one except splines on starter end are tapered off vs square ends on old one. The new one also has a 1/4 inch felt washer between it and the rear shoulder. Was thinking I could put a bushing behind it to keep it from going too far back or perhaps I could"stake" it with punch. Looks like the front is staked on the inner bushing as was the older one.
Bob
12-27-2004 14:41:00
 Re: Bendex in reply to Hayfarmer, 12-27-2004 07:24:36
It sounds like you have the wrong starter drive ("Bendix").
Is there a reliable local auto electrical shop you can check with to get the correct one?
If you keep messing with it and it sticks engaged when the engine starts, you'll ruin the starter, and possibly the flywheel ring gear. Not worth taking that chance!
Post the make and model number from the starter tag, and the make and part number of the replacement bendix, and I'll see if I can look it up, to see if it matches.
Post the number (if any) stamped into the armature, also.
