Battery Drain
Rex H.
12-25-2004 14:17:48
I am getting a battery drain with the switch off on my JD 4440. When I take all three wires off the alternator there is no drain. There seems to be current draw on terminal two of the alternator. The alternator is only 4 months old , but I guess that it could have gone bad. Is there any testing I can do before I have to call a mechanic?
twopop
12-25-2004 14:27:22
 Re: Battery Drain in reply to Rex H., 12-25-2004 14:17:48
if you have a 12 volt test light.pull the plug on the side of the alt.test both terminals for power.if you have power on both wires,the problem is not the alt.if you dont have power on both wires,it is the alt.this is for a delco 10si type alt.if its has a motorola alt the test is about the same,check to see if you have power on the two small wires.if with the key off,you have power on all wires,the problem is in the tractor wiring
Bob
12-25-2004 14:26:30
The alternator terminal labeled #1 on should have battery voltage only when the key is "ON".
The alternator terminal labeled #2 WILL have battery voltage all the time, key "ON" or key "OFF".
If these 2 wires get mixed up, the battery will be drained while the tractor is shut off. Check with a meter or test light.
If only #2 and the large output stud are powered up when the key is "OFF", and the battery is draing through the alternator, you have an internal alternator problem.
