jdemaris
12-25-2004 18:14:49
Re: JD 1010 questions in reply to terryj, 12-25-2004 00:50:12
To my knowledge, Deere never made any gas powered 1010s that were negative ground. I've got all the factory wiring diagrams. There were three serial number breaks, #1 up to 16648, #2 16649-42000 and #3 42001 and up. It's easy to hook up the ground either way - if desired. There were some 24 volt diesels but they also used a positive system ground. I run both my 1010s with negative ground mainly because I've got 12 volt neg. ground Delco alternators on them. As far as the ignition circuit goes, there were updates made by Deere company that will not show in the original wiring diagrams. So, I can send you original circuit diagrams, but they will NOT reflect the updates. Basically (as I recall) the ignition improvements were thus. I did a lot of them as a Deere mechanic in the late 60s and up. I'm going by memory but, in general - the original 1010s and 2010s with gas engines had ballast resistors. Some were built into the ignition switches, and some were updated with remote mounted resistors. It really makes no difference as long as you find a way to limit current to the coil during regular running and have some sort of resistor bypass so full current can flow to the coil when cranking/cold starting. Since the 1010 usually has a Delco starter on it, the Delco solenoid already has a built in resistor bypass pole on it marked "R." So, that's the easiest and most reliable way to do it. Have a 16 gauge (or larger) wire run from that "R" terminal to the post on the coil that does NOT go to the distributor. That may be negative or positive depending on what battery ground system you've chosen to use. Positive ground system has switched power going to the negative terminal on the coil - and if negative ground - it's vice-versa. So, if you have your system hooked as positive ground, you will have a wire run from the "R" terminal of the solenoid to the negative terminal on the ignition coil. Also, from the same negative coil terminal a wire must run to a ballast resistor, and from there to the IGN terminal of the ignition switch. That's - if you have a conventional ignition switch. If you have the special Deere switch with it's own built in resistor and key-bypass in it, things are different. It's a simple system, but like anything, you need to get it right. You need full current to the coil when the engine is cranking, and less current - via a resistor -when the engine is running. You can avoid all this if you change over to an electronic setup that eliminates the points and resistor. Also, keep in mind that almost all the Deere gas engines from 1960 and up used 6 volt coils in their 12 volt systems. Always seemed odd, and it was hard on ignition points, but it seems Deere felt their gas engines needed the extra ignition jolt that a 6 volt coil would provide when run with 12 volts. Many times we installed 12 volt coils instead in an effort to enhance point life and it seemed to make cold started a little harder (but we did not conduct a scientific study on the matter). If you've got one of those odd-ball Prestolite starters without the built in ignition bypass, then you will have to use the special ignition switch, or mount an extra relay, or use a coil with an built-in resistor, or don't use a resistor at all and change your points more often.
