Item to make 3pt lift higher??????
Chris
02-11-2004 19:47:22
I was at a sale the other day and there was a piece of equipment you put on your 3pt then put the implement into it and it had a scissor effect that made it lift higher like for loading hay with the 3pt if you know who manufactures these id like to know. Thanks Chris
MapleSprings
02-12-2004 05:03:14
 Re: Item to make 3pt lift higher?????? in reply to Chris , 02-11-2004 19:47:22
Orchard Equipment in Conway MA sells -- or at least used to -- such a device for lifting bins of fruit higher than the usual 3pt would raise.
Still, this would not lift as high as the bale lifters others have mentioned, and I don;t know if you need that much lift or not.
You can find the Orchard Equipment website and 800 phone number at>Link
Good>Link luck.
Mark
Brad
02-12-2004 04:29:55
Its a high lift. Go to sweettractor.com and look under new implements for high lift. looks like a handy tool to move big bales.
MIKE HANLEY
02-11-2004 21:08:09
The only thing that comes to my mind, is that HESSTON had a rig that mounted on the 3 PT. The part that mounted on the 3 PT went stright up in the air. Off the top of that was an arm that was run by a cylinder so the arm could go from the ground to,,,,,what maybe,,,,,14' high. Off the end of the arm there was a 4 prong grapple fork. It was for feeding hay stacks that were made by their stack wagons. I thought I had some lit on it but can't find it now. Even looked at one till I figured out that it took a pretty good size tractor with all the front end weights you could put on it to safely keep the front end down. Over the years I think I have seen maybe 3 of them. I would guess that it was discontinued when HESSTON discontinued the stack wagons.
MIKE HANLEY
02-11-2004 21:24:44
 Re: Re: Item to make 3pt lift higher?????? in reply to MIKE HANLEY, 02-11-2004 21:08:09
Another thing that comes to mind is something I saw in FARM SHOW. That was a rig that fit onto the 3PT and a standard bale fork attached to that so that a round bale could be lifted high enought to be put on a wagon or truck bed. My back issues of FARM SHOW are about 18" high. Can't recall if it was something that some one made, and was offered to make them for others or what. FARM SHOW is on line and thier web has a index for back issues. Without a key surch word, it will take some time to find it. try hay, round bale, 3PT (etc.)
